MHB Prove $\sqrt{a}+\sqrt{b}+\sqrt{c}+\sqrt{d}\le 10$ w/ $a,b,c,d>0$
  • Thread starter Thread starter anemone
The discussion focuses on proving the inequality $\sqrt{a}+\sqrt{b}+\sqrt{c}+\sqrt{d}\le 10$ under the conditions that $a, b, c, d > 0$, $a \le 1$, $a + b \le 5$, $a + b + c \le 14$, and $a + b + c + d \le 30$. Participants explore various mathematical approaches and inequalities, such as the Cauchy-Schwarz inequality, to validate the claim. The constraints on the variables are critical in deriving the upper limit of the sum of square roots. The proof ultimately hinges on the relationships between the variables and their upper bounds. The conclusion affirms that the inequality holds true given the specified conditions.
anemone
MHB
POTW Director
Prove that if $a,\,b,\,c,\,d>0$ and $a\le 1,\,a+b\le 5,\,a+b+c\le 14,\,a+b+c+d\le 30$, then $\sqrt{a}+\sqrt{b}+\sqrt{c}+\sqrt{d}\le 10$.
Mathematics news on Phys.org
Did I miss something, or is this problem really quite easy to solve? Thankyou for any comment!
Given the conditions:
$a \leq 1 \;\;\wedge \;\;a+b \leq 5\;\; \wedge \;\;a+b+c\leq 14\;\; \wedge \;\; a+b+c+d \leq 30$
which by successive subtractions implies:
$a \leq 1 \;\;\wedge \;\;b \leq 4\;\; \wedge \;\;c\leq 9\;\; \wedge \;\; d \leq 16$
or:
$\sqrt{a} \leq 1 \;\;\wedge \;\;\sqrt{b} \leq 2\;\; \wedge \;\;\sqrt{c}\leq 3\;\; \wedge \;\; \sqrt{d} \leq 4$
Adding the four inequalities yields:
$\sqrt{a} +\sqrt{b} +\sqrt{c}+\sqrt{d} \leq 1+2+3+4 = 10.$
or:
a = .2 b = 4.6 does not satisfy your consideration.
Thankyou for your comment. You´re right of course. I did miss something ... :(
Given the constraints on the 4 partitions of the value 30 it is true that the maximum value of the sum of the square roots of these partitions is 10. The problem is proving it.
It can be shown that the sum of the square roots of 2 partitions of a value is greater than or equal to the square root of the unpartitioned value and that the value of the sum of the square roots of the 2 partitions is maximized when the partitions are equal. The equation is:
$\sqrt{a}+\sqrt{b} = \sqrt{a+b+2\sqrt{ab}}$
let the value being partitioned = 1 then a+b=1 and b=a-1 and the equation becomes:
$\sqrt{a}+\sqrt{b} = \sqrt{1 + 2\sqrt{a(1-a)}}$
and it can be seen that as $a$ ranges from 0 to 1, the maximum value of the sum of the square roots of the two partitions is at $a$ = 1/2. We should be able to use induction to show that whatever the values of the 2 partitions, any additional partitions of the original two partitions can only increase the value of the sum of the square roots of all the partitions. Applying this to the constraining inequalities given for the four partitions we find that
a=1, b=4, c=9 and d=16 give the maximal value for the sum of the square roots of these four partitions within the given constraints and that this sum is 10 which demonstrates the assertion.
The function $f: (0,\,+\infty)\rightarrow (0,\,+\infty)$ defined by $f(x)=\sqrt{x}$ is concave, and therefore for any positive real numbers $k_1,\,k_2,\,\cdots, \,k_n$ such that $k_1+k_2+\cdots+k_n=1$, we have
$k_1f(x_1)+k_2f(x_2)+\cdots+k_nf(x_n)\le f(k_1x_1+k_2x_2+\cdots+k_nx_n)$
Now, take $n=4$ and $k_1=\dfrac{1}{10},\,k_2=\dfrac{2}{10},\,k_3=\dfrac{3}{10},\,k_4=\dfrac{4}{10}$. It follows that
$\dfrac{1}{10}\sqrt{a}+\dfrac{2}{10}\sqrt{\dfrac{b}{4}}+\dfrac{3}{10}\sqrt{\dfrac{c}{9}}+\dfrac{4}{10}\sqrt{\dfrac{d}{16}}\le \sqrt{\dfrac{a}{10}+\dfrac{b}{20}+\dfrac{c}{30}+\dfrac{d}{40}}$
or
$\sqrt{a}+\sqrt{b}+\sqrt{c}+\sqrt{d}\le 10\sqrt{\dfrac{12a+6b+4c+3d}{120}}$
But
$12a+6b+4c+3d=3(a+b+c+d)+(a+b+c)+2(a+b)+6a\le 3(30)+14+2(5)+6(1)=120$
and the claim is then proved.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
