MHB Prove Summation Inequality: $\frac{1}{2n-1} > \sum_{k=n}^{2n-2}\frac{1}{k^2}$
The discussion focuses on proving the inequality $$\sum_{k=n}^{2n-2}\frac{1}{k^2}<\frac{1}{2n-1}$$ for integers $n \geq 2$. Participants utilize the concept of lower Riemann sums and compare the sum to the integral of the function $1/x^2$ over the interval $[n-1, 2n-2]$, which yields a value less than $\frac{1}{2n-1}$. They also explore a telescoping series approach to simplify the sum and establish the inequality through algebraic manipulation. The conclusion confirms that the inequality holds for the specified range of $n$.
MarkFL
MHB
Prove the following:
$$\sum_{k=n}^{2n-2}\frac{1}{k^2}<\frac{1}{2n-1}$$ where $$2\le n$$
Mathematics news on Phys.org
[sp]$$\sum_{k=n}^{2n-2}\frac{1}{k^2}$$ is the lower Riemann sum for the function $1/x^2$ on the interval $[n-1,2n-2]$ using subintervals of length $1$. That is less than the value of the integral of the function over that interval, namely $$\int_{n-1}^{2n-2}\frac1{x^2}\,dx = \left[-\frac1x \right]_{n-1}^{2n-2} = -\frac1{2n-2} + \frac1{n-1} = \frac1{2n-2} < \frac1{2n-1}.$$[/sp]
Hi Opalg,
At the end of your proof you write $\frac{1}{2n-2} < \frac{1}{2n-1}$, but in fact $\frac{1}{2n-2} > \frac{1}{2n-1}$.
Euge said:
Hi Opalg,
Oops, seems like I was having a senior moment there. (Blush)
Let's hope this attempt is better than the previous one.
[sp]$k^2>k^2-1 = (k-1)(k+1)$. Therefore $$\frac1{k^2} < \frac1{(k-1)(k+1)} = \frac1{2(k-1)} - \frac1{2(k+1)},$$ from which $$\sum_{k=n}^{2n-2}\frac{1}{k^2}< \sum_{k=n}^{2n-2}\Bigl(\frac1{2(k-1)} - \frac1{2(k+1)}\Bigr).$$ The sum on the right telescopes, leaving two orphan terms at the beginning and two at the end, to give $$\sum_{k=n}^{2n-2}\frac{1}{k^2}< \frac1{2(n-1)} + \frac1{2n} - \frac1{2(2n-2)} - \frac1{2(2n-1)} = \frac1{4(n-1)} + \frac1{2n} - \frac1{2(2n-1)}.$$ We want this to be less than (or equal to) $$\frac1{2n-1}$$, in other words $$\frac1{4(n-1)} + \frac1{2n} \leqslant \frac3{2(2n-1)}.$$ Multiply through by the denominators to see that this is equivalent to $$n(2n-1) + 2(n-1)(2n-1) \leqslant 6n(n-1).$$ That in turn is equivalent to $$\cancel{6n^2} -7n+2 \leqslant \cancel{6n^2} - 6n,$$ $$-n\leqslant-2.$$ Thus the given inequality holds provided that $n\geqslant2$.[/sp]
Hi Opalg,
Yes, this proof works! Nice one! (Cool)
Nicely done, Opalg! (Yes)
Here's my solution:
We are given to prove:
Using induction, we first check the base case $P_2$:
$$\sum_{k=2}^{2\cdot2-2}\frac{1}{k^2}<\frac{1}{2\cdot2-1}$$
$$\sum_{k=2}^{2}\frac{1}{k^2}<\frac{1}{2\cdot2-1}$$
$$\frac{1}{2^2}<\frac{1}{2^2-1}$$
This is true, since the denominator on the right is smaller and the numerators are equal. Taking what we are given to prove as $P_n$, we see that we want to add to the left:
$$-\frac{1}{n^2}+\left(\frac{1}{2(n+1)-2}\right)^2=\left(\frac{1}{2n}\right)^2-\frac{1}{n^2}=-\frac{3}{4n^2}$$
And we want to add to the right:
$$\frac{1}{2(n+1)-1}-\frac{1}{2n-1}=\frac{1}{2n+1}-\frac{1}{2n-1}=\frac{2n-1-2n-1}{(2n+1)(2n-1)}=-\frac{2}{4n^2-1}$$
So, what we need to show is that:
$$-\frac{3}{4n^2}<-\frac{2}{4n^2-1}$$
If we simultaneously invert both sides and multiply through by -6, the direction of the inequality remains the same, and we have:
$$8n^2<12n^2-3$$
Subtract through by $8n^2$:
$$0<4n^2-3$$
This is true for $2\le n$, thus we may add:
$$-\frac{1}{n^2}+\left(\frac{1}{2(n+1)-2}\right)^2<\frac{1}{2(n+1)-1}-\frac{1}{2n-1}$$
to $P_n$:
to get:
$$-\frac{1}{n^2}+\sum_{k=n}^{2n-2}\frac{1}{k^2}+\left(\frac{1}{2(n+1)-2}\right)^2<\frac{1}{2(n+1)-1}+\frac{1}{2n-1}-\frac{1}{2n-1}$$
which then simplifies to:
$$\sum_{k=n+1}^{2(n+1)-2}\frac{1}{k^2}<\frac{1}{2(n+1)-1}$$
We have derived $P_{n+1}$ from $P_n$ thereby completing the proof by induction.
[sp]
MarkFL said:
... we want to add to the left:
I think that what you need to add on the left is $$-\frac1{n^2} + \frac1{(2n-1)^2} + \frac1{(2n)^2}$$ (Instead of going from $n$ to $2n-2$, the summation will go from $n+1$ to $2n$. So there is one term dropped from the start, but two terms added at the end.) That is why I could not make the proof by induction work.[/sp]
Opalg said:
[sp]
You are absolutely correct...for each increment of $n$ the number of terms in the sum increases by 1. I will try to fix my proof soon. :)
Because we find:
$$\frac{d}{dx}\left(x^{-2}\right)=-2x^{-3}$$
which is increasing as $x$ increases, we may state:
$$\sum_{k=n}^{2n-2}\frac{1}{k^2}<\int_{n}^{2n-1}\left(x-\frac{1}{2}\right)^{-2}\,dx$$
Hence:
$$\sum_{k=n}^{2n-2}\frac{1}{k^2}<\left.-\frac{1}{x-\dfrac{1}{2}}\right|_{n}^{2n-1}$$
$$\sum_{k=n}^{2n-2}\frac{1}{k^2}<\frac{1}{n-\frac{1}{2}}-\frac{1}{2n-\dfrac{3}{2}}$$
$$\sum_{k=n}^{2n-2}\frac{1}{k^2}<2\left(\frac{1}{2n-1}-\frac{1}{4n-3}\right)$$
$$\sum_{k=n}^{2n-2}\frac{1}{k^2}<2\left(\frac{4n-3-2n+1}{(2n-1)(4n-3)}\right)$$
$$\sum_{k=n}^{2n-2}\frac{1}{k^2}<\frac{4n-4}{4n-3}\cdot\frac{1}{2n-1}<\frac{1}{2n-1}$$
