Prove that 0.999.... = 1 is a contradiction
In summary, The "proof" is fatally flawed and is trying to prove something that is false. Almost every step of it is wrong.
mustang19
75
Prove that 0.999... = 1 is a contradiction
None
Assumptions :
A. Let g(x) be a function of the form
G(1) = 0.999^2
G(2) = 0.9999^2
Etc for all integer x > 0
B. 0.999... = 1
Argument:
1. G(1) ends in decimal 1 or 8
2. G(2) ends in decimal 1 or 8
3. By linear relation all g(n) ends in decimal 1 or 8
4. G(infinity) = 0.999... Squared
5. G(infinity) = 1 ^2 by assumption (b)
6. By (3), G(infinity) ends in decimal 1 or 8
7. 1^2 ends in a decimal value of zero
8. By (6), (7), and assumption (b), contradiction
9. QED 0.999... = 1 is a contradiction.
I'm not sure what you're trying to do here. You can't prove that this is a contradiction, because it's true. Are you supposed to prove that 0.999... = 1 using a proof by contradiction?
mustang19 said:
None
Assumptions :
G(1) = 0.999^2
G(2) = 0.9999^2
B. 0.999... = 1
Argument:
The right-most digit of G(1) is 1, not 8
Same here. The right-most digit of G(2) is 1, not 8.
What do you mean, "by linear relation"?
This makes no sense. Infinity is not a number, the expression G(∞) is meaningless.
You can't use assumption B as part of your proof, since that's precisely what you're trying to prove.
Likes taverner
Mark44 said:
What is assumption b?.
Mark, I suppose that OP used a word-processor which was doing Auto-capitalization.
Likely that assumption b is:
mustang19 said:
B. 0.999... = 1
Yes I noticed that just before you posted. I also noted that he said he has to "Prove that 0.999... = 1 is a contradiction."
He's going to have a hard time doing that...
Likes Tazerfish and SammyS
As Mark indicated above, you will have a hard time completing your proof.
mustang19 said:
Assumptions :
G(1) = 0.999^2
G(2) = 0.9999^2
Firstly:
You should be more consistent. Is the function g(x), or is it G(x) .
(I'll use g.)
There is no mystery here:
g(1) = 0.9992 = 0.998001
g(2) = 0.99992 = 0.99980001​
This does not get you anywhere, but ...
the square of a 0 followed by a decimal point followed by N 9s gives
a 0 followed by
(N− 1) 9s followed by
an 8 followed by
(N− 1) 0s followed by
a 1 .​
Likes Mark44
Okay so I don't see any criticism of the proof. Closing question.
... other than @Mark44 's comment that G(infinity) makes no sense?
Also, he asks you to define what you mean when you say "by linear relation".
Let me ask this:
Can you give me a positive number that's less than (1 − 0.9999... ) ?​
Likes jim mcnamara
See post #2.
What you have isn't a proof, nor is it clear what you're trying to prove.
Likes russ_watters, FactChecker and jim mcnamara
Ok, then to be more clear -- The "proof" is fatally flawed and is trying to prove something that is false. Almost every step of it is wrong.
Likes bhobba and Mark44
Let me ask this:
That's another contradiction
By linear relation
Is there a value of g(n) where that does not hold?
I suspect that your difficulty with accepting the fact that 0.999... = 1 is that you have a lack of understanding of the concept of infinity.
Likes bhobba
Okay
Using terms like "linear" incorrectly does not convince me of anything. So here is a simple and direct way that you can convince me -- answer this question:
If the numbers 1 and 0.9999... are not equal, you must be able to give me a number in between the two. What is that number?
Likes Demystifier, opus and SammyS
That's a contradiction
Thread closed for Moderation...
Related to Prove that 0.999.... = 1 is a contradiction
What is the meaning of "0.999...."?
"0.999...." is a decimal representation of the number nine-tenths, which can also be written as 0.9 or 9/10.
Why is it considered a contradiction that 0.999.... = 1?
It is considered a contradiction because 0.999.... is infinitely close to, but not equal to, 1. In other words, there is an infinite number of 9s after the decimal point, indicating that 0.999.... is always approaching but never reaching 1.
How can you prove that 0.999.... = 1 is a contradiction?
There are several ways to prove this, but one simple way is to use algebra. We can rewrite 0.999.... as a fraction, which is 9/10. Then, we can multiply both sides of the equation by 10 to get 9.999.... = 10. This shows that 0.999.... is not equal to 1, as there is a difference of 0.000....1 between the two numbers.
Are there any real-life applications of understanding why 0.999.... = 1 is a contradiction?
Yes, understanding this concept is important in fields such as mathematics, computer science, and physics. It helps us to understand the concept of infinity and the limitations of using decimal representations of numbers.
Is there a different way to represent the number nine-tenths without using decimal notation?
Yes, there are other ways to represent nine-tenths, such as fractions (9/10), percentages (90%), or ratios (9:10). However, decimal notation is often the most common and convenient way to represent numbers in everyday situations.
