Prove that (-1,1) is homeomorphic to R (real numbers)
In summary: The statement that a homeomorphic function must be continuous and invertible implies that the function is a one-to-one correspondence between the underlying set and the homeomorphic set. This is what is meant by the term "homeomorphism."
madness
815
70
Prove that (-1,1) is homeomorphic to R (real numbers), with the topology given by the usual metric.
None.
I constructed the function f(x) = [1/(1-x) - 1/(1+x)]/2 = x/[(1+x)(1-x)] which is continuous and maps (-1,1) to R. Next I need to show that f has a continuous inverse. I'm stuck here.
Can you use theorems such as the formula for the derivative if the inverse of an increasing function?
Or if not that, there is a similar looking trig function that might be easier to work with.
It's not all that difficult to explicitely find the inverse function using the quadratic formula.
Then the only "technical difficulty" is if y= 0.
I'm still not sure. This is a topology course so no difficult analysis type theorems should be involved I think. To prove that the function (not its inverse) is continuous is it sufficient to say that it is a rational function who's denominator is non-zero on the interval?
I can't think of any simpler trig function to use either.
That is "whose", not "who's". Think about tan(x) appropriately modified. Hard for us to know what theorems your instructor expects you to know and use. At some level, your statement about rational function would be sufficient to claim continuity.
Hehe thanks for the spelling tip. Is it really so simple as f(x) = tan(pi*x/2) and
x = (2/pi)arctan(y)?
And hopefully since these are well known functions I don't have to prove that they're continuous right?
Hi,I am doing a question very similar to this, but still don't understand... can you possibly explain further?
What don't you understand?
sorry, I think I get it now, but is it just enough to say that since f(x) as above is continuous and bijective, and x is continuous, therefore (-1,1) homeomorphic to the reals?
The inverse* of a continuous bijection need not be continuous.
*: as defined when viewing it as a function on the underlying sets
oh ok, it's just a definition that I have written down says a homeomorphic function must be continuous and invertible and the inverse function must also be continuous? Is that not necessarily true?
so for madness' question above for example, would it suffice to say:
Take f(x) as tan(pi*x/2) and f^-1(x) as (2/pi)arctan(y)
this shows that (-1,1) is homeomorphic to the reals?
That seems too easy? Does anything else need to be proved?
No, what you said here is true.
It is also true that there exist continuous bijections whose inverse is not continuous.
So when taken together, what do these imply?
the inverse of a continuous bijection need not be continuous, but the inverse of a homeomorphic function must be continuous? ...hence the idea of a homeomorphism?
FAQ: Prove that (-1,1) is homeomorphic to R (real numbers)
1. What is the definition of a homeomorphism?
A homeomorphism is a continuous bijective function between two topological spaces that has a continuous inverse function.
2. How do you prove that (-1,1) is homeomorphic to R (real numbers)?
To prove that (-1,1) is homeomorphic to R, you need to show that there exists a continuous bijective function from (-1,1) to R and that this function has a continuous inverse function.
3. What is the difference between a homeomorphism and an isomorphism?
A homeomorphism preserves the topological structure of a space, while an isomorphism preserves the algebraic structure of a space. In other words, a homeomorphism preserves the relationships between points in a space, while an isomorphism preserves the operations and structures within a space.
4. Can you give an example of a homeomorphism?
One example of a homeomorphism is the function f(x) = 2x that maps the interval (0,1) to (0,2). This function is continuous, bijective, and has a continuous inverse function, making it a homeomorphism between the two spaces.
5. Why is proving that (-1,1) is homeomorphic to R important?
Proving that (-1,1) is homeomorphic to R is important because it allows us to understand and compare the topological properties of these two spaces. It also helps us to generalize concepts and theorems from one space to another, making it a useful tool in mathematical analysis and other fields of science.
