Prove that (6^n -1) is always divisible by 5
  • Thread starter Kaldanis
So it works for n = k, so it works for n = k + 1. So it works for all natural numbers n. In summary, to prove that for all natural numbers n, 6^n - 1 is divisible by 5, we can use induction. The base case is n = 1, where 6^1 -
Kaldanis
106
Prove that for all natural numbers n, [tex]6^n -1[/tex] is divisible by 5.
I'm not sure how to go about proving this. I know that 6 to the power of any natural number ends in 6, therefor subtracting 1 will always make it end in a 5. This proves that it is divisible by 5. I asked my maths tutor and his reply was "I'm not sure how to go about that", then after a while he said try induction. If I try to prove it by induction I can't get past the base case without being lost.
Does anyone have any tips or advice?
For your induction hypothesis, let n = k, and assume that assume that 6k -1 is divisible by 5. What's another way to say this?
Now, let n = k + 1, and use the induction hypothesis to show that 6k+1 - 1 is also divisible by 5.
Hi Mark, I'm thinking like crazy, how about this?
Since n = k and we're assuming 6k -1 is divisible by 5, I could declare that 6k -1 = 5x, where x is some natural number.
Then I need to show that 5x + 6k+1 -1 is all divisible by 5... is that anywhere near right?
I think you only need to show that
6k+1 - 1 = 5y,
for some other natural number y.
To prove some hypothesis by induction you need three things:
  • A mapping from the assertion to the natural numbers.
    In a sense you aren't trying to prove just one assertion: You are trying to prove an infinite number of them. Here, the nth assertion (call it Pn) is that 6n-1 is divisible by 5.
  • A base case for which you can prove the hypothesis to be true.
    Setting n to 1 yields P1, that 61-1 is divisible by 5. It's not too hard to prove this base case.
  • An induction step where you prove that if Pn is true then Pn+1 will also be true.
    In other words, you don't have to prove Pn. You assume it to be true. What you do have to do is prove that given this assumption then Pn+1 is necessarily true. In this case, you have to show that if 6n-1 is a multiple of 5 then so is 6n+1-1.
And that is all you have to do. Once you have proven both the base case and the induction step, you have proven the hypothesis to be true.
Regarding this problem, the base case is trivial. The induction step is a bit tougher, but not too tough.
Hint: What is (6n+1-1) - (6n-1) ?
My suggestion is to express 6 in terms of 5 and then use the binomial theorem.
As I have given this away you should go on and formulate a general theorem because 6 and 5 are of quite limited interest.
Look at [itex](a+1)(a^n-1)=a_{n+1}+a^n-a-1[/itex]
[itex]=a_{n+1}-1+a^n-1-(a-1)[/itex]​
I haven't read the last 2 posts yet because I felt like I was close and wanted to get the final part on my own. I realized that for example, 65 is just 64*6, so how is this?
6k+1 -1 = 6(6k) -1
= (5+1)(6k) -1
= 5(6k)+6k -1
= 5(6k)+6(6k-1) -1
= 5(6k)+(5+1)(6k-1) -1
= 5(6k)+5(6k-1)+6k-1 -1
= ... +5(62) +5(61) +6 -1
Basically, following the same rule that 6k = 6(6k-1), you can continue back until you get to 61 which is 6.
I'm not sure how clear that is, but is it 'acceptable' as a proof? I'll go and read the last few posts now :)
6k+1 -1 = 6(6k) -1
= (5+1)(6k) -1
= 5(6k)+6k -1
= 5(6k)+6(6k-1) -1
No, I don't think so. You aren't using the induction hypothesis; i.e., that 6k - 1 = 5m, for some integer m.
It looks good to me.
Can be generalised.
"..." doesn't fly in an induction proof.
Taking what I had further and carrying on from above:
6k+1 -1 = 6(6k) -1
= (5+1)(6k) -1
= 5(6k)+6k -1
= 5(6k)+6(6k-1) -1
So it can be simplified to 5(6k + 6k-1 + 6k-2 + 6k-3 + ... + 62 + 61) + 6 -1.
Let everything in the brackets = X, then...
6k+1 -1 = 5X + 5!
Not an induction proof, but a proof I thought.
I was really happy when I got what I wrote in the last post, but if it's wrong then I'm not sure how to write it without the "..." in there
The induction hypothesis is that 6k - 1 = 5m for some integer m.
If n = k + 1,
6k+1 -1 = 6(6k) -1
= 6(6k - 1) +6 - 1
= 6*5m + 5
= 5(6m + 1), which is clearly divisible by 5.
Okay, you win. I really like your way of showing it!
But is my way 100% wrong?
No, it's not 100% wrong, but if your instructor is asking for an induction proof, then your way would be marked wrong, or at least would not get full credit. Pretty much any time you write "..." there's some other induction proof lurking about.
Not at all wrong IMO.
But maybe the more proofs you have the better you understand and familarise even if one is sufficient.
Binomial theorem as I mentioned is another. But now I just realized that 6n - 1 is just an example of difference of two n-th powers for which there is a standard formula.
Thanks to everyone who helped, I was struggling with proving things like this but the steps here apply to quite a few other problems I have. I'm trying to get as much experience with these as possible
FAQ: Prove that (6^n -1) is always divisible by 5
What is the statement being proved?
The statement being proved is that (6^n - 1) is always divisible by 5, where n is any positive integer.
Why is this statement important?
This statement is important because it demonstrates a mathematical property that holds true for all positive integers n. It can also be used in various mathematical proofs and applications.
What is the proof for this statement?
The proof for this statement uses mathematical induction. It can be shown that for n = 1, (6^1 - 1) = 5, which is divisible by 5. Then, assuming the statement holds true for n = k, it can be shown that it also holds true for n = k+1. Therefore, the statement holds true for all positive integers n.
Can this statement be generalized to other values besides 6?
Yes, this statement can be generalized to other values of x. In general, (x^n - 1) is always divisible by (x-1), where x and n are positive integers. The proof follows a similar mathematical induction approach.
How can this statement be applied in real-life situations?
This statement can be applied in various areas of mathematics and science, such as number theory, algebra, and computer science. It can also be used in solving certain types of equations and problems involving divisibility. Additionally, this statement can be used to prove other mathematical theorems and properties.
