MHB Prove that A - (B U C) = (A - B) ∩ (A - C)
  • Thread starter Thread starter KOO
The discussion focuses on proving the set identity A - (B ∪ C) = (A - B) ∩ (A - C) using set operations. The left-hand side is simplified using De Morgan's laws and properties of set intersection, leading to the expression (A ∩ B^c) ∩ (A ∩ C^c). Participants challenge the correctness of the initial steps, pointing out errors in the final expressions. A clearer approach is suggested, emphasizing the use of definitions and properties of set subtraction and intersection. The proof ultimately confirms the validity of the identity through logical equivalences.
KOO
Let A, B, and C be three sets. Prove that A-(BUC) = (A-B) ∩ (A-C)
Solution)
L.H.S = A - (B U C)
A ∩ (B U C)c
A ∩ (B c ∩ Cc)
(A ∩ Bc) ∩ (A∩ Cc)
(AUB) ∩ (AUC)
R.H.S = (A-B) ∩ (A-C)
(A∩Bc) ∩ (A∩Cc)
(AUB) ∩ (AUC)
L.H.S = R.H.S
Is this correct?
Re: Prove that A - (BUC) = (A-B) ∩ (A-C)
Solution)
L.H.S = A - (B U C)
A ∩ (B U C)c
A ∩ (B c ∩ Cc)
(A ∩ Bc) ∩ (A∩ Cc)
(AUB) ∩ (AUC)
(A∩Bc) ∩ (A∩Cc)
(AUB) ∩ (AUC)
L.H.S = R.H.S
Is this correct?
(A ∩ Bc) ∩ (A∩ Cc) = (AUB) ∩ (AUC) , this is not correct you could use
A ∩ Bc = A - B , and A∩ Cc=A - C
In fact
(A ∩ Bc) = (AcUB)c
The red lines are false are and they are not useful, you solved it but the last lines are not equal to the previous ones
$$x \in A-(B \cup C) \leftrightarrow x \in A \wedge x \notin B \cup C \rightarrow x \in A \wedge x \notin B \wedge x \notin C \\ \leftrightarrow (x \in A \wedge x \notin B) \wedge (x \in A \wedge x \notin C) \leftrightarrow x \in A-B \wedge x \in A-C \leftrightarrow x \in (A-B) \cap (A-C)$$
Hello, KOO!
We should work on one side of the equation.
Let A, B, C be three sets.
Prove that:.A - (B \cup C) \:=\: (A-B) \cap (A-C)
\begin{array}{cccccc}<br /> 1. &amp; A -(B \cap C) &amp;&amp; 1. &amp;\text{Given} \\<br /> 2. &amp; A \cap(B\cup C)^c &amp;&amp; 2. &amp;\text{def. Subtr&#039;n} \\<br /> 3. &amp; A \cap B^c \cap C^c &amp;&amp; 3. &amp; \text{DeMorgan} \\<br /> 4. &amp; A \cap A \cap B^c \cap C^c &amp;&amp; 4. &amp; \text{Duplication} \\<br /> 5. &amp; A\cap B^c \cap A \cap C^c &amp;&amp; 5. &amp; \text{Commutative} \\<br /> 6. &amp; (A \cap B^c) \cap (A \cap C^c) &amp;&amp; 6. &amp; \text{Associative} \\<br /> 7. &amp; (A-B) \cap (A-C) &amp;&amp; 7. &amp; \text{def. Subtr&#039;n}\end{array}
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
