Prove that a given graph contains a cycle using induction (Graph Theory)
In summary: But our longest path was n-1 edges, so we have one edge left over, and it must connect to some vertex we've already seen. That would create a cycle.In summary, to prove that a graph with the number of vertices less than or equal to the number of edges contains at least one cycle, we can use strong induction along the number of vertices. For the base case, we can use a graph with one vertex and one edge, which forms a cycle. For the inductive case, we can consider a graph with at least two vertices and a degree of at least 2, and find a longest path from v0 to vn. This path must have n-
Superyoshiom
29
My Problem: Given a Graph G = (V,E), where the number of vertices is less than or equal to the number of edges, use induction to prove that the graph contains at least one cycle (the graph is not required to be completely connected).
My attempt: For my base case, I used only one vertex with one edge, and if I just made the edge connect the vertex to itself, that would form a cycle. The inductive case is where I'm having trouble with this problem. At first, I thought that I could have k number of vertices for a graph, and that current graph would contain at least one cycle. Then that would lead me to two cases: we could add a k+1 vertex to our connected graph and still have that original cycle intact or put the k+1 vertex by itself, thereby creating at least two cycles, one from the original k vertices and one cycle of the k+1 vertex connected to itself.
However, the professor said this would be an example of weak induction, and that there are many more cases to take into account when solving that type of induction, so to use strong induction instead. However, aside from the base case, I'm unsure as to how I would use strong induction to solve this problem. One thought I have is to assume that I have a graph that already contains a cycle, and then start removing vertices and edges to see if it still contains a cycle, but I still see that as running into the same problems as before.
Thanks for the help in advance!
Mathematics news on Phys.org
I do not understand this. I guess we may assume that ##G\neq \emptyset##. Then if there is no edge, and the number of vertices is less or equal zero, so it has no vertices either and is empty. As we ruled this out, we have at least one edge.
Sorry, I made a type, it should read: Given a Graph G = (V,E), where the number of vertices is less than or equal to the number of edges, use induction to prove that the graph contains at least one cycle
I changed the OP to reflect this
I would perform the induction along the number of vertices, since you cannot control the edges. Your argument for the base is correct. Now assume that every graph with ##k < n## vertices and at least ##k## edges contains at least one cycle.
Now we have a graph with ##n## vertices and no less than ##n## edges, say ##m \geq n## edges. What happens if we remove a vertex and with it possible edges?
I guess if we remove a vertex that's adjacent to two or more other vertices we'd end up removing more edges than vertices so we'd get a graph that doesn't follow that rule of V<=E.
If we do that, then should we assume that we'd lose cycles as a result because we are removing potential edges that could be used to form cycles?
You probably will have to consider cases. If we do not remove an edge, we are done. What happens with two, three etc. many edges removed? And we have still the possibility to remove another vertex. Maybe you should make a table with ##m## and ##n##.
Here's an idea I got with some research:
For the inductive case, I could have a graph in which the degree of vertices is at least >= 2. Then I find a longest path from v0 to vn, and since we know that v0 is degree 2 or greater, one of those edges from v0 must either connect to a vertex on its path thereby creating a cycle or connect to some outside vertex m, which we can then just add to our longest path.
Since the number of edges must be >= the number of vertices, we can see that a "straight-line" sort of path wouldn't work since something like O---O---O would have three vertices and 2 edges.
At that point, can we just inductively remove vertices and edges until we reach the base case, proving this to be true each time?
Why not simply pick any node which has less than or equal to the average number of edges and remove it?
Such a node is guaranteed to exist anywhere outside Lake Wobegon.
Related to Prove that a given graph contains a cycle using induction (Graph Theory)
1. How does induction work in graph theory?
In induction, we start by proving that a statement is true for a base case, usually the smallest possible case. Then, we assume that the statement is true for a given case, and use that assumption to prove that it is also true for the next case. This process is repeated until we reach the desired case.
2. What is a cycle in graph theory?
A cycle in graph theory is a path in a graph that starts and ends at the same vertex, and does not pass through any other vertex more than once.
3. How do we use induction to prove the existence of a cycle in a given graph?
To prove the existence of a cycle in a given graph using induction, we first prove that the graph contains a cycle of length 3 (the base case). Then, we assume that the graph contains a cycle of length k, and use that assumption to prove that the graph also contains a cycle of length k+1. This process is repeated until we reach the desired cycle length.
4. Can induction be used to prove the absence of a cycle in a graph?
No, induction can only be used to prove the existence of a cycle, not its absence. To prove that a graph does not contain a cycle, we need to use other methods, such as a direct proof or a proof by contradiction.
5. Are there any limitations to using induction in graph theory?
Induction can only be used to prove statements that follow a specific pattern, such as the existence of a cycle in a graph. It cannot be used to prove all statements in graph theory, so it is important to understand when it is applicable and when other methods should be used.
  • General Math
  • General Math
