Prove that a sequence is eventually decreasing.
In summary: I don't really follow.try subtracting the n+1 term of the sequence from the nth term. if this quantitiy is less that zero the the sequence is decreasing. however you can factor out a to the power n. this is greater than zero so it doesn't matter. look at the other factor, if you choose a <N+1 you get the desired result.In summary, the sequence \frac{a^{n}}{n!} is eventually decreasing for large n.
The_Iceflash
50
Prove that if a > 0, the sequence [tex]\frac{a^{n}}{n!}[/tex] is eventually decreasing for large n.
N/A
I know I'm to prove this by finding the index but I'm at a loss on how to find the index on such a sequence as I'm not used to using a variable that's in the sequence.
To warmup I was given a values 110 and 300 to find an index for but with 'a' being in the sequence itself I'm not sure how to do that.
Try showing that [itex]n! - a^n[/itex] is eventually increasing.
N/A
The numerator and denominator are products of n terms but each term in the numerator is a while the terms in the denominator are increasing. The "average" value (geometric average since we are multiplying) in the denominator is [itex]\sqrt[n]{n!}[/itex]. Can you show that, for fixed a, there exist an integer, n, such that [itex]\sqrt[n]{n!}> a[/itex]?
Related to Prove that a sequence is eventually decreasing.
1. What is a sequence?
A sequence is a list of numbers that follow a specific pattern or rule. It can be finite or infinite in length.
2. How can you prove that a sequence is eventually decreasing?
To prove that a sequence is eventually decreasing, you must show that there exists a point in the sequence where all subsequent terms are smaller than the previous term.
3. What are the different methods for proving that a sequence is eventually decreasing?
There are several methods for proving that a sequence is eventually decreasing, including induction, direct proof, and contradiction.
4. What is the importance of proving that a sequence is eventually decreasing?
Proving that a sequence is eventually decreasing is important because it allows us to make predictions about the behavior of the sequence and determine its long-term behavior.
5. Can a sequence be eventually decreasing without being strictly decreasing?
Yes, a sequence can be eventually decreasing without being strictly decreasing. This means that there may be some terms in the sequence that are equal, but overall, the sequence is still decreasing.
