MHB Prove that every nonzero vector in V is a maximal vector for T.
  • Thread starter Thread starter toni07
    Vector
toni07
Let $T: V \rightarrow V$ be a linear operator on a fi nite-dimensional vector space $V$ over $F$. Assume that $_{\mu T}(x) \in F[x]$ is an irreducible polynomial.
I don't understand how assuming that the minimal polynomial is prime helps to prove the question. Please help.
Re: Prove that every nonzero vector in $V$ is a maximal vector for $T$
Prove which question?
Note that if the field is the field of the real numbers, then the polynomial $x^2+\pi$ is irreducible, which has little to do with primes.
The question in the title: Prove that every nonzero vector in $V$ is a maximal vector for $T$.
Ah. I missed that.
And I presume that with prime you mean irreducible.
Well. Let's see.
Suppose $V$ is n-dimensional.
Then, if $F$ is algebraically closed (such as the complex numbers), $T$ has n eigenvalues.
If at least 2 eigenvalues are distinct, then the minimal polynomial is reducible.
Therefore all eigenvalues have to be equal.
That means that each nonzero vector has to be a maximal vector for $T$.
If $F$ is the field of the real numbers, we can extend it to the complex numbers, and the same argument holds.
So we're left with all other fields that do not obey the same principles.
Are you supposed to prove it for any field?
The thread title should give a brief description of the problem, while the problem itself should be fully given within the body of the first post. As you can see, putting the question in the title leads to confusion. :D
The world of 2\times 2 complex matrices is very colorful. They form a Banach-algebra, they act on spinors, they contain the quaternions, SU(2), su(2), SL(2,\mathbb C), sl(2,\mathbb C). Furthermore, with the determinant as Euclidean or pseudo-Euclidean norm, isu(2) is a 3-dimensional Euclidean space, \mathbb RI\oplus isu(2) is a Minkowski space with signature (1,3), i\mathbb RI\oplus su(2) is a Minkowski space with signature (3,1), SU(2) is the double cover of SO(3), sl(2,\mathbb C) is the...
