Prove that f approaches a limit near a if and only if a = 0
In summary, the limit does not exist for functions that oscillate between rational and irrational values near a.
lordianed
23
Let ##f## be defined by ##f(x) = x## if ##x## is rational, and ##f(x) = -x## if ##x## is irrational, prove that ##\lim_{x\to a} f(x)## exists if and only if ##a=0##.
Epsilon-delta definition of a limit: ##\lim_{x\to a}f(x) = l## means that for every ##\epsilon > 0## there exists a ##\delta >0## such that for all ##x##, if ##0<|x-a|<\delta##, then ##|f(x)-l|<\epsilon##.
Its negation: There exists some ##\epsilon >0## such that for all ##\delta >0##, there exists some ##x## for which ##0<|x-a|<\delta## but not ##|f(x)-l|<\epsilon##.
[/B]
##(\Leftarrow)##
Suppose that ##a = 0##, I guess guess that ##\lim_{x\to 0}f(x) = 0##. Let ##\epsilon > 0## be arbitrary and choose ##\delta = \epsilon##. For all ##x## that satisfy ##0<|x|<\delta##, ##x## is either rational or irrational. If ##x## is rational, then ##|f(x)| = |x| < \epsilon##; otherwise if ##x## is irrational, then ##|f(x)| = |-x| = |x| <\epsilon##, then by definition ##\lim_{x\to 0}f(x) = 0##.
##(\Rightarrow)##
Attempting a proof by contrapositive: Suppose that ##a \neq 0##, and let ##l## be arbitrary, then it must be shown that for some ##\epsilon >0##, for all ##\delta >0##, there exists some ##x## for which ##0<|x-a|<\delta## but not ##|f(x)-l|<\epsilon##.
This step is problematic for me,
I am unable to find such an ##\epsilon##, I know that it most likely has to be related to ##\delta##, but I am unable to systematically find it. Any help would be greatly appreciated :)
Hint: Any finite interval contains both rational and irrational numbers.
Likes lordianed
There is a typo here, ##\epsilon## is most likely related to ##a##.
Use the sequential definition of the limit, and density results
Thank you for the hints and correction Orodruin and Samy, I will mull over them; and thanks for your suggestion geoffrey, however the question is from Spivak's Calculus which does not cover sequences until much later, I'm sorry that I don't quite understand what you're telling me.
I would forget about ##\epsilon - \delta## first and look at what happens to the function near non-zero points. E.g. ##x = \pm 1##, ##x = \pm 10##, ##x = \pm 0.1##. Try to see why the limit does not exist. Then, of course, you have to turn this understanding into a formal ##\epsilon - \delta## proof. But, if you don't understand why something is or is not true, then it's hard to produce an ##\epsilon - \delta## proof.
Thank you for the suggestion PeroK, I know that this may not sound very mathematically correct, but near any non-zero point a, the values of the function do not tend towards a singular value but instead we have the function get close to the negative and positive values of that point, where the points 'oscillate' between values near a and -a. In drawing this I got a graph that looked sort of like y=x and y=-x put together in the same graph, and it seemed to make sense to me that the limit at the non-zero points do not exist, however I am at a loss as to how to put this mathematically, perhaps I have to give it more thought.
So, for ##a<>0##, you will have points ##x## as close as you want to ##a## where ##|f(a)-f(x)|## will be "very close" to ##|2a|##.
Now remember that you can choose ##\epsilon>0## based on the specific ##a## you are considering. What you have to do now is translate the "very close" from the previous sentence into a more formal argument.
Likes lordianed
Orodruin almost gave you the solution. The key point is that between any two real numbers you can find a rational number and an irrational number, and that these two numbers can be chosen as close as you wish.EDIT: Remember that the last line of your ##\epsilon - \delta## proof should be ##|\ell| < \epsilon##.
Likes lordianed
Okay, so two things.
1) You understand the function, but you cannot (yet) map the behaviour of the function to the epsilon-delta regime. Nothing unusual there, everyone struggles with this to begin with.
2) If you look at your "oscillation" at each point, you may find the clue to the formal proof. Suppose a limit exists at ##x = a##: call it ##L##, say. Then, all function values for ##x## close to ##a## must be close to ##L##. This means that all function values close to ##a## must be close to each other. Not necessarily as close as they are to the limit, but close to each other nevertheless. This property is called being a "Cauchy" sequence. You don't need to know this, but the concept is useful here. At ##x = 10##, say, the function values do not get close to each other (some get close to ##10## and some get close to ##-10##, so the limit cannot exist).
Here's a suggestion. Try to prove that for ##x = 10## that the limit is not ##0##. This is just one specific case. The first step is to find an ##\epsilon##. Can you guess a suitable ##\epsilon## for this case?
Likes lordianed
Here's what I have so far everyone, This is my approach to the idea that for ##a=10## the limit is not ##0##. I take ##\epsilon = 10##, for any ##\delta > 0##, I know that I can find ##x## in the interval ##0<x-10< \delta##, in which case ##|x| > 10##.
For the general case, here is what I've been thinking. I have to prove that ##\lim_{x \to a} \neq l## for all ##a \neq 0## and all ##l##. Upon observing I realize ##\epsilon = |a|## could be the required epsilon, and I've divided my proof into cases, where ##a## is positive or negative, and whether ##l \geq 0## or ##l < 0##. Here's the idea:
Partial attempt at proof:
Suppose that ##a > 0##.
Case 1, ##l\geq 0##. Taking ##\epsilon = |a|##, for any choice of ##\delta##, we choose ##x## such that ##0<x-a<\delta##; since in any real interval I can find rational and irrational ##x##, I choose ##x## to be irrational, in which case ##f(x) < -|a|##, and thus ##|f(x) - l| > |l|+|a| \geq |a|##.
Case 2, ##l < 0##. Take ##\epsilon = |a|##, for all ##\delta## choose ##x## such that ##0<x-a<\delta## and is rational, then ##f(x) > |a|##, and therefore ##|f(x) - l| > |l|+|a| > |a|##.
Am I getting the right idea?
Yes, you're definitely getting the idea. I wouldn't worry if it seems quite pedestrian. I think it's a good idea to do the separate cases until you get the hang of things.
Thank you for the help everyone, I am very pleased to have received it! :) I have my proof written in full and will continue to do more questions.
Why don't you show once and for all that ##\ell = 0## ?
Since ##f(a) \in \{ -a, a\}##, and since ##a\in [a -\delta , a + \delta]##, then ## |a| = |f(a)| = |f(a) -\ell | < \epsilon##.
And therefore ## a = 0 ##
FAQ: Prove that f approaches a limit near a if and only if a = 0
What does it mean for a function to "approach a limit" near a specific value?
When we say a function approaches a limit near a value, it means that as the input values of the function get closer and closer to the given value, the output values of the function also get closer and closer to a specific number.
How is this concept related to the idea of a limit in calculus?
In calculus, the concept of a limit is used to describe the behavior of a function as the input values approach a specific value. When we say a function approaches a limit near a value, we are essentially saying that the limit of the function exists at that value.
What is the significance of proving that a function approaches a limit near a value?
Proving that a function approaches a limit near a value is important because it allows us to make accurate predictions about the behavior of the function. It also helps us understand the behavior of the function at points where it may not be defined.
How do we prove that a function approaches a limit near a value using the limit definition?
To prove that a function approaches a limit near a value, we use the limit definition which states that for a function f(x) approaching a limit near a value a, for any positive number ε, there exists a positive number δ such that if |x - a| < δ, then |f(x) - L| < ε. This essentially means that the values of the function will get closer and closer to the limit value L as the input values get closer and closer to the given value a.
What is the significance of the statement "if and only if a = 0" in proving that a function approaches a limit near a value?
The statement "if and only if a = 0" means that the function approaches a limit near a value a only if the value of a is equal to 0. This is significant because it helps us determine the behavior of the function at a specific value, and also aids in finding the limit of the function at that value.
