Prove that f(x)>=0 for all x in R iff b^2-ac=<0
  • Thread starter Robb
In summary, the conversation discusses finding the minimum value of a function and using the hypothesis of a>0 to show that the function is positive. The expression ##b^2-ac \leq 0## is used to show that the minimum value is greater than or equal to 0. It is also mentioned that the second derivative test for extrema can be used to show that the function is positive.
Robb
225
This is where I'm at and I'm not sure what my next step is. Any help would be much appreciated!
Great work so far! You made a sign mistake at the last equality though.
You want that ##f(x) \geq 0## for all ##x \in \mathbb{R}##, or equivalently (why??) ##\min f = \frac{-b^2 +ac}{a} \geq 0##. Can you proceed? Note that the hypothesis ##a>0## is essential to proceed.
This is where I'm not sure. I tried setting min f = (-b^2+ac)/a and solving for x but I'm not sure if that tells me anything and it doesn't relate to the hypothesis. I guess I'm unsure of how to use the hypothesis.
That expression doesn't depend on ##x##...
It really is one line to get the right answer from here.
Does it have to do with divisibility of a, which must be greater that zero?
Yes, certainly.
When is the following statement true?
##ax \geq 0 \iff x \geq 0##
for all x in R?
Robb said:
for all x in R?
I forgot to mention that ##x \in \mathbb{R}## is fixed. I want a condition for ##a##.
(a) must be greater than zero but that's a given
Yes, indeed. Apply this and you will be done (in fact, you have to apply it to ##1/a## instead of ##a##)
How does b^2-ac =< 0 tell us that f(x) >= 0?
##b^2 - ac \leq 0 \implies \frac{ac -b^2}{a} \geq 0##
Since ##\frac{ac -b^2}{a} = \min f##, we know that ##\min f \geq 0##. It is now obvious that ##f \geq 0##, as ##f \geq \min f \geq 0##
NOW I GET IT! I was looking at min f as f' min. I assume I could also apply the second derivative test for extrema? So, f" = 2a, and we know a>0, hence f is positive?
FAQ: Prove that f(x)>=0 for all x in R iff b^2-ac=<0
What does the statement "f(x)>=0 for all x in R" mean?
The statement means that the function f(x) always has a non-negative value for any input value x from the set of real numbers.
What is the significance of b^2-ac in the given statement?
b^2-ac is the discriminant of a quadratic equation, which determines the nature of the roots of the equation. In this case, if b^2-ac is less than or equal to zero, the quadratic equation has either two real roots or no real roots, which is necessary for f(x) to be non-negative for all x in R.
How can we prove that f(x)>=0 for all x in R?
To prove that f(x)>=0 for all x in R, we need to show that the discriminant b^2-ac is less than or equal to zero for any real values of a, b, and c in the quadratic equation. This can be done by using the quadratic formula or by completing the square.
Can we use any other method to prove the given statement?
Yes, there are other methods to prove that f(x)>=0 for all x in R. For example, we can use the properties of a quadratic function, such as its vertex, to show that the function always has a non-negative value for any input x in the set of real numbers.
What is the practical application of proving that f(x)>=0 for all x in R?
The practical application of this proof is that it ensures the reliability and validity of the quadratic function in various mathematical and scientific applications. It also helps in solving optimization problems and in determining the nature of solutions to real-world problems represented by quadratic equations.
