Prove that ## gcd(a, n)=gcd(b, n) ##.
  • Thread starter Thread starter Math100
If a ≡ b mod n, then it follows that gcd(a, n) = gcd(b, n). The proof begins by establishing that n divides (a - b), leading to the conclusion that the greatest common divisors d and h of a and b with respect to n must divide each other. The argument highlights that if d divides both a and n, it must also divide b, and vice versa for h. The discussion also notes the importance of considering the positivity of the gcd, as the equality holds only up to units in the integers. Thus, the proof confirms that under the given modular condition, the gcds of a and b with respect to n are indeed equal.
Math100
If ## a\equiv b \mod n ##, prove that ## gcd(a, n)=gcd(b, n) ##.
None.
Proof:
Suppose ## a\equiv b \mod n ##.
Then ## n\mid (a-b)\implies kn=a-b ## for some ## k\in\mathbb{Z} ##.
Let ## gcd(a, n)=d ## and ## gcd(b, n)=h ##.
Note that ## d\mid a \land d\mid n\implies d\mid (a-kn)\implies d\mid b ## and ## h\mid b \land h\mid n\implies h\mid (b+kn)\implies h\mid a ##.
Thus ## d\mid n \land d\mid b\implies d\mid gcd(b, n)\implies d\mid h ## and ## h\mid n \land h\mid a\implies h\mid gcd(a, n)\implies h\mid d ##.
Therefore, if ## a\equiv b \mod n ##, then ## gcd(a, n)=gcd(b, n) ##.
Math100 said:
Homework Statement:: If ## a\equiv b \mod n ##, prove that ## gcd(a, n)=gcd(b, n) ##.
Relevant Equations:: None.
Proof:
I'm not sure whether this is the most elegant way to write it, but it is correct. Maybe a few too many ##\Longrightarrow ##.A common technique is to prove only ##d\,|\,h## and state that ##h\,|\,d## for symmetry reasons.
Also, there is an error in all of it. Any statement about divisors is always only true up to units. Units are invertible numbers, integers in this case. The only units in the ring of integers are ##\pm 1.## Hence we cannot conclude equality unless we add the requirement that the greatest common divisor has to be positive, which might be the case, I don't know. But from ##d\,|\,h ## and ##h\,|\,d## alone, we only get ##d=\pm h.##
Let ## gcd(a, n)=d ## and ## gcd(b, n)=h ## where ## d ## is a positive integer.
Note that ## d\mid a\land d\mid n\implies d\mid (a-kn)\implies d\mid b ##.
Thus ## d\mid n\land d\mid b\implies d\mid gcd(b, n)\implies d\mid h ##.
Conversely, ## h\mid d ## by symmetry.
Since ## d\mid h ## and ## h\mid d ##,
it follows that ## d=h\implies gcd(a, n)=gcd(b, n) ##.
