Prove that l^p is a subset of l^q for all p,q from 1 to infinity
  • Thread starter Thread starter cbarker1
    Infinity
cbarker1
MHB
Prove that l^p is a subset of l^q for all p,q from 1 to infinity. Then prove it is strict subset. First, prove that a^t<=a for all t,a in (0,1]. Then prove that finite sum of |x_i|^t<= the sum of |xi|.
a^t<=a for all a,t
p-norm's definition.
Dear everyone,
I am having trouble with this problem. I have convinced myself that the ##a^t-a\leq 0## is true. Now, I am trying to applying this inequality for the finite series and I don't know where to start. After that, proving that the p-norm is less or equal to the q-norm.
Thanks,
Cbarker1
Is there a condition on p and q, such as q &lt; p? Otherwise you are being asked to prove l^p \subsetneq l^q \subsetneq l^p which is impossible.
If you have two sequences of non-negative numbers, with the property that each element of the first sequence is less than or equal to the corresponding element of the second sequence, what can you say about the sums of those sequences?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
