Prove that lim x -> 0 sin (1/x) doesn't exist
  • Thread starter Portuga
  • Tags
    Sin
In summary: One minor problem is that:\lim_{x\rightarrow0+}\sin\left(\frac{1}{x}\right)=\lim_{u\rightarrow\infty}\sin uThis is not fatal to your proof, but what you have is not quite right. It's better to stick with sequences going to 0.
Portuga
56
prove that
[tex]
\lim_{x\rightarrow 0} \sin \left( \frac{1}{x} \right)
[/tex] doesn't exist.
[tex]
\lim_{x\rightarrow0}\sin\left(\frac{1}{x}\right)=\lim_{u\rightarrow\infty}\sin u
[/tex]
My strategy to solve this problem is to make [itex] u \rightarrow \infty [/itex] through different paths and show that the limits are different.
So, first one is [itex] a_{u}=\frac{\pi}{2}+2\pi u,\,u\in\mathbb{N} [/itex]. Second one is [itex]
b_{u}=u\pi,\,u\in\mathbb{N}[/itex].
Both these have the same behavior as [itex] u \rightarrow \infty [/itex]:
[tex]
\lim_{u\rightarrow\infty}a_{u}=\lim_{u\rightarrow\infty}b_{u}=\infty.
[/tex]
For with first one,
[tex]
\begin{aligned}\lim_{u\rightarrow\infty}\sin a_{u} & =\lim_{u\rightarrow\infty}\sin\left(\frac{\pi}{2}+2\pi u\right)\\ & =\lim_{u\rightarrow\infty}\sin\left(\frac{\pi}{2}\right)\cos2\pi u+\sin2\pi u\cos\left(\frac{\pi}{2}\right)\\ & =\lim_{u\rightarrow\infty}\sin\left(\frac{\pi}{2}\right)\cos2\pi u+\lim_{u\rightarrow\infty}\sin2\pi u\cos\left(\frac{\pi}{2}\right)\\ & =\lim_{u\rightarrow\infty}\cos2\pi u+\lim_{u\rightarrow\infty}\sin2\pi u\cos\left(\frac{\pi}{2}\right). \end{aligned}
[/tex]
The limit [itex]
[/itex] tends to 0, as [itex]
[/itex] tends to 0, and [itex]
\sin2\pi u
[/itex] is limited both upper and lower bound.
Therefore, [tex]
\lim_{u\rightarrow\infty}\sin a_{u}=1.
[/tex]
Now, [tex]
\lim_{u\rightarrow\infty}\sin b_{u}=\lim_{u\rightarrow\infty}\sin u\pi=0,
[/tex] as, [itex] \forall u, u\pi [/itex] is an multiple of [itex]\pi[/itex], which [itex] \sin [/itex] is null.
Then, [tex]
\lim_{u\rightarrow\infty}\sin b_{u}=0.
[/tex]
Because of these two different results for different paths, it's true that [tex]
\nexists\lim_{x\rightarrow0}\sin\frac{1}{x}.
[/tex]
Am I correct?
Thanks in advance!
It looks okay, but could have been a lot simpler:
##\sin(\frac{\pi}{2} + 2\pi u) = \sin{\frac{\pi}{2}} = 1##
Also, you could just let ##a_u = \frac{1}{\frac{\pi}{2} + 2\pi u}## and keep the limits going to ##0##.
Likes Portuga
You are overthinking this. The individual functions are constant, their limit is easy to find.
Directly using sequences for the original function is better, because it avoids issues with the sign change at 0.
Likes Portuga
You mean, I should use [itex]
a_{u}=\frac{1}{\frac{\pi}{2}+2\pi u},\,u\in\mathbb{N}
[/itex] and [itex]
[/itex] since the beggining, correct?
[/itex] and [itex]
I thought you were using the idea of finding two sequences that converge to 0 but for which the two sequences of function values converge to different values. That looks fine as an approach. Changing the limit to ##\infty## requires a bit more justification.
Likes Portuga
Yes, that's exactly what's my initial approach was: two sequences converging to same value, but producing different limits with [itex] \sin \left( \frac{1}{x} \right) [/itex].
Portuga said:
[tex]
[/tex]
[tex]
[/tex]
Related to Prove that lim x -> 0 sin (1/x) doesn't exist
1. What does it mean for a limit to not exist?
A limit does not exist if the value of the function at a certain point does not approach a single finite value as the independent variable approaches a particular value. In other words, the function has different values or does not approach a value at all as the independent variable approaches the specified value.
2. Why is it important to prove that lim x -> 0 sin (1/x) doesn't exist?
It is important to prove that lim x -> 0 sin (1/x) doesn't exist because it helps us understand the behavior of the function and its limitations. This information can be useful in various applications, such as in calculus, engineering, and physics.
3. How do you prove that lim x -> 0 sin (1/x) doesn't exist?
To prove that lim x -> 0 sin (1/x) doesn't exist, we need to show that the function has different values or does not approach a value as x approaches 0. This can be done by considering different paths or approaches towards 0, such as approaching from positive and negative values, or using a specific sequence of values for x.
4. Can we determine the limit of sin (1/x) as x approaches 0 by simply evaluating the function at x = 0?
No, we cannot determine the limit of sin (1/x) as x approaches 0 by evaluating the function at x = 0. This is because the function is undefined at x = 0 and does not have a single finite value at this point. The limit can only be determined by considering the behavior of the function as x approaches 0.
5. What other functions have a non-existent limit at a specific point?
Other functions that have a non-existent limit at a specific point include those with vertical asymptotes, such as tan x and sec x as x approaches π/2 or -π/2, and those with jump discontinuities, such as floor(x) and ceiling(x) at integer values of x. There are also more complex functions that have non-existent limits, such as the Dirichlet function at all non-zero points.
  • Calculus
