Prove that ## p_{n+3}^{2}<p_{n} p_{n+1} p_{n+2} ##
  • Thread starter Thread starter Math100
For integers n ≥ 3, it is proven that p_{n+3}^2 < p_n p_{n+1} p_{n+2} by applying Bertrand's Postulate, which states p_{n+1} < 2p_n. The proof is demonstrated through two specific cases: for n = 3, p_6^2 = 169 is less than p_3 p_4 p_5 = 385, and for n = 4, p_7^2 = 289 is less than p_4 p_5 p_6 = 1001. For n > 4, the smallest prime p_n is at least 11, leading to the conclusion that p_{n+3}^2 < 8p_{n+1} p_{n+2} < p_n p_{n+1} p_{n+2}. Thus, the inequality holds for all integers n ≥ 3.
Math100
Let ## p_{n} ## denote the nth prime number. For ## n\geq 3 ##, prove that ## p_{n+3}^{2}<p_{n} p_{n+1} p_{n+2} ##.
[Hint: Note that ## p_{n+3}^{2}<4p_{n+2}^{2}<8p_{n+1} p_{n+2} ##.]
None.
Proof:
Let ## n\geq 3 ## be an integer.
Applying the Bertrand's Postulate produces:
## p_{n+1}<2p_{n} ##.
Then ## p_{n+3}<2p_{n+2} ##.
Thus ## p_{n+3}^{2}<4p_{n+2}^{2}<4p_{n+2} (2p_{n+1})=8p_{n+2} p_{n+1} ##.
Now we consider two cases.
Case #1: Suppose ## n=3 ##.
Then ## p_{6}^{2}=169<p_{3} p_{4} p_{5}=385 ##.
Thus ## p_{n+3}^{2}<p_{n} p_{n+1} p_{n+2} ## for ## n=3 ##.
Case #2: Suppose ## n=4 ##.
Then ## p_{7}^{2}=289<p_{4} p_{5} p_{6}=1001 ##.
Thus ## p_{n+3}^{2}<p_{n} p_{n+1} p_{n+2} ## for ## n=4 ##.
Therefore, ## p_{n+3}^{2}<p_{n} p_{n+1} p_{n+2} ## for ## n\geq 3 ##.
Math100 said:
Homework Statement:: Let ## p_{n} ## denote the nth prime number. For ## n\geq 3 ##, prove that ## p_{n+3}^{2}<p_{n} p_{n+1} p_{n+2} ##.
Relevant Equations:: None.
Proof:
So you have applied the hint, but the work below doesn't take things any further.
This won't fly. You can't jump from establishing the equation for ##p_6^2## and ##p_7^2##, and then make the leap ("Therefore") to ##p_n^2##.
What should I do then?
You need to continue what you were doing with the hint.
Assume ## p_{n+1}<2p_{n} ## for ## n\geq 5 ##.
Then ## p_{n+3}^{2}<4p_{n+2}^{2}<8p_{n+1} p_{n+2}<11p_{n+1} p_{n+2}=p_{5} p_{n+1} p_{n+2}\leq p_{n} p_{n+1} p_{n+2} ##.
Note that ## p_{n}\geq 11 ## for ## n\geq 5 ##.
Thus ## p_{n+3}^{2}<4p_{n+2}^{2}<8p_{n+1} p_{n+2}<p_{n} p_{n+1} p_{n+2} ##.
Likes Maarten Havinga
This is much better, although there is still a lot of stuff here that doesn't need to be included. E.g. in the 4th line under Case#2, you say "Assume ## p_{n+1}<2p_{n} ## for ## n\geq 5 ##."
You don't need to include Bertrand's Postulate again.
You also don't need Case 2, where n = 4.
Edit: It turns out that you do need this case.
If n = 4, the hint doesn't apply, but ##289 = 17^2 = p_{4 + 3}^2 = p_7^2 < p_4p_5p_6 = 7*11*13 = 1001##.
So the statement is proved for n = 4.
If n = 3, you're dealing with ##p_6, p_5,## and ##p_4##, which are 13, 11, and 7, respectively.
##169 = p_6^2 < 8p_1p_2 = 8\cdot11\cdot7 = 615##, so the statement is true for n = 3
If n > 3 n > 4 the smallest prime of the three primes on the right side of the statement to be proved is always ##\ge 11##, so ##p_{n+3}^3 < 8p_{n+1}p_{n + 2} < p_np_{n+1}p_{n + 2} ##.
Mark44 said:
If n > 3, the smallest prime of the three primes on the right side of the statement to be proved is always ##\ge 11##, so ##p_{n+3}^3 < 8p_{n+1}p_{n + 2} < p_np_{n+1}p_{n + 2} ##.
##p_4=7 < 8.##
fresh_42 said:
##p_4=7 < 8.##
If n = 4, then ##p_{n + 3} = p_7##, which is 11, and 8 < 11.
##p_n## is relevant, not ##p_{n+3}## (compare post #1 and hint therein).
Here's the problem statement and hint, from post #1.
My work for ##p_4## had on off-by-one error, so this prime needs its own case, contrary to what I said earlier.
##289 = p_7^2 < 8*p_5*p_6## per the hint. While it's true that ##8 > p_4 = 7##, it is nevertheless true that ##289 < p_4p_5p_6 = 7*11*13 = 1001##
For n = 5, we have ##361 = 19^2 = p_8^2 < 8p_6p_7 < p_5p_6p_7 = 11*13*17 = 2431##
For n > 5, the smallest prime in the product of the three primes, ##p_n## is at least 13, which is larger than 8.
So for any integer ##n \ge 3##, ##p_{n + 3}^2 < p_np_{n+1}p_{n+2}##.
That statement is not relevant at this point.
Two problems: 1. There is no reason to assume that, because it is implied by Bertrand's postulate. 2. You are about to use Bertrand's postulate twice. You have to state exactly how you are using it. Merely restating the postulate does not do the job.
You have to justify the first two inequalities. Use Bertrand's postulate to do so.
You've said this twice now. Once is usually enough.
