Prove that PA=2BP in the problem involving parametric equations
chwala
Let P be a point on the curve ##x=t^2, y=\dfrac{1}{t}##. If the tangents to the curve at P meets the x- and y-axes at A and B respectively, prove that PA=2BP.
Parametric equations
My take;
##\dfrac{dy}{dx}=\dfrac{-1}{t^2}⋅\dfrac{1}{2t}=\dfrac{-1}{2t^3}##
The equation of the tangent line AB is given by;
##y-\dfrac{1}{t}=\dfrac{-1}{2t^3}(x-t^2)##
##ty=\dfrac{-1}{2t^2}(x-t^2)+1##
At point A, ##(x,y)=(3t^2,0)##
At point B, ##(x,y)=(0,1.5t)##
PA=##\sqrt{(x_2-x_1)^2+(y_2-y_1)^2}##
=##\sqrt{(t^2-3t^2)^2+(\dfrac{1}{t}-0)^2}##
= ##\dfrac{\sqrt{4t^6+1}}{t}##
BP=##\sqrt{(x_2-x_1)^2+(y_2-y_1)^2}##
=##\sqrt{(t^2-0)^2+(\dfrac{1}{t}-\dfrac{1.5}{t})^2}##
= ##\dfrac{\sqrt{4t^6+1}}{2t}##
it follows that ##\dfrac{PA}{BP}##=##\dfrac{\sqrt{4t^6+1}}{t}\div\dfrac{\sqrt{4t^6+1}}{2t}=2##
##⇒PA=2BP##thus proved.
insight welcome or other approach.
You can use tools such as https://www.geogebra.org/m/cAsHbXEU to plot the curve.
Draw the tangent, AB, at some arbitrary point P.
Drop a perpendicular from P ##(t^2, \frac 1t)##.to meet the (say) x-axis at Q. Note that Q has coordinates ##(t^2, 0)##
You have already established that point A is ##(3t^2,0)##. You can now complete the proof using proportionality (the triangle proportionality theorem).
Parametrize the tangent as <br /> (t^2, t^{-1}) + \lambda(2t, -t^{-2}). From here it is straightforward to find the intercepts at A = (3t^2,0) and B = (0, \frac32t^{-1}) and then compute <br /> \begin{split}<br /> |PA| &amp;= \sqrt{ (2t^2)^2 + (-t^{-1})^2 } = \sqrt{ 4t^4 + t^{-2}} \\<br /> |PB| &amp;= \sqrt { (-t^2)^2 + \left(\tfrac12 t^{-1}\right)^2 } = \sqrt{ t^4 + \tfrac14t^{-2}} \\<br /> &amp;= \tfrac12 |PA|<br /> \end{split}
