Prove that |suba| < |a| for all a=0
  • Thread starter NWeid1
In summary, we can prove that |sin(a)| < |a| for all x≠0 by restricting the domain to non-negative a and showing that the resulting function's derivative is always non-negative. This result can then be used to show that the only solution to the equation sinx=x is x=0. When trying to find all intersections with a graphing calculator, it may not accurately display all solutions due to the nature of trigonometric functions.
NWeid1
82
Prove that |sina| < |a| for all x≠0 and use the result to show that the only solution to the equation sinx=x is x=0. What happens if you try to find all intersections with a graphing calculator?
I know for the first part you have to use MVT, but I've always been bad with the MVT, hence me being here :).
Well, first thing's first, it's good to remember that the absolute value of an odd function is an even function. So we can essentially ignore a<0, because if |sin(a)|≥|a| for any a<0, it'll also be true for some a>0. So it'll help to restrict the domain a bit. After that... well, I'm still working on after that.
Actually, after looking at this, I don't think the Mean Value Theorem is entirely necessary. (Feel free to correct me if I'm wrong, people who are better than me at this!) First, since we restricted our domain to non-negative a, we can throw the absolute value signs off the right side:
|sin(a)|≤a for a≥0
Then subtract |sin(a)| from both sides and prove that the resulting function's (a-|sin(a)|, to be exact) derivative is never negative. That, along with the fact that at a=0, the function is 0, and the fact that the original function is even, should prove what you're trying to prove.
FAQ: Prove that |suba| < |a| for all a=0
How do you prove that |suba| < |a| for all a=0?
To prove this statement, we can use the definition of absolute value. We know that the absolute value of a number is always positive, so |suba| and |a| must both be greater than or equal to zero. Therefore, if |suba| < |a|, it means that |suba| is closer to zero than |a|, which can be represented as 0 < |suba| < |a|. This statement is true for all values of a=0.
What is suba in this statement?
In this statement, suba refers to a subset of a. This means that suba is a smaller value of a compared to a itself. For example, if a=5, then suba could be 3 or 4. The statement is saying that the absolute value of suba is always smaller than the absolute value of a when a=0.
Can you provide an example to illustrate this statement?
Sure, let's take a=0. In this case, the statement becomes |sub0| < |0|. Since the absolute value of 0 is 0, this simplifies to |sub0| < 0. However, since the absolute value of any number is always greater than or equal to 0, this statement is always true.
Is this statement true for all values of a, or just when a=0?
This statement is only true when a=0. If a is any other value, then suba could potentially be equal to or greater than a, making the statement false. However, when a=0, suba can only be 0, which is always less than 0.
How can this statement be useful in scientific research?
This statement can be useful in many scientific fields, such as mathematics, physics, and chemistry. For example, it can be used to prove inequalities or to simplify mathematical equations. In physics, it can help to determine the magnitude of a vector or the distance between two points. In chemistry, it can be applied to determine the strength of a solution or the concentration of a substance. Overall, this statement is a fundamental concept in mathematics and can be applied in various scientific studies.
