Prove that tangents to the focal cord of parabola....
In summary: So, in summary, by considering two rays traveling vertically down and reflecting along a focal chord of a parabola, and labeling the angles of incidence for each ray as ##a## and ##b##, we can use rules of reflection and the triangle formed by the focal chord and the two tangents to prove that the angle between the tangents is right, thus proving that tangents to the focal chord are perpendicular using the reflection property of parabola.
Vriska
138
Prove that tangents to the focal cord of parabola are perpendicular using the reflection property of parabola ( A ray of light striking parallel to the focal plane goes through the focus, and a ray of light going through the focus goes parallel)
I don't know whether this is solvable with just this much detail, just something I've been thinking about, looks doable but I've not been able to get anywhere. The geometry is quite tangled.
Mathematics news on Phys.org
The geometry is reasonably simple as long as one approaches it from the correct perspective.
Consider a parabola in the number plane whose axis of symmetry is the y-axis and the apex is the origin. Now consider two rays that travel vertically down and are reflected along the focal chord, which is horizontal. One of the rays descends at abscissa ##a## and the other at abscissa ##-a##, where the value of ##a## depends on the shape of the parabola.
Consider the ray that comes down at abscissa ##a##. What is the angle between its incident ray and its reflection? What does that enable us to say about the angle between the focal chord (along which the reflected ray travels) and the tangent to the parabola at the point of reflection?
The angle between the reflected and incident is 90 - the angle of the tangent wrt the perpendicular is 45. I'm not sure what to do after this, I'm still finding the geometry tangled
OK, now what about the tangent at the point of reflection of the ray that comes down at abscissa ##-a##.
What can we then say about the angle between that and the other tangent?
One is 45 the other is - 45. Angle between them is 90
andrewkirk said:
You're welcome.
? noo , not this, the question was to prove *any* focal chord through the focus (not only latus rectum) has tangents that are perpendicular. I can do it with analytical geometry, but i want to do it with the reflection thing.
The OP said *the*, not *any*.
But in any case, the argument needs only minor adjuistment to apply it to any focal chord. Just consider the two rays heading parallel to the parabola axis after reflection at either end of a given focal chord. Label the angle of incidence for one of those rays ##a## and that for the other as ##b##. Using rules of reflection and completing the triangle formed by the focal chord and the two tangents we see that the angle between the tangents is right.
Likes Vriska
Ah thank you so much, the triangle thing was brilliant - and simple.
Related to Prove that tangents to the focal cord of parabola....
1. What is a focal chord of a parabola?
A focal chord of a parabola is a line segment that passes through the focus of the parabola and is parallel to the directrix of the parabola. It is also known as a double ordinate.
2. How do you prove that tangents to the focal chord of a parabola are equal in length?
To prove that tangents to the focal chord of a parabola are equal in length, we can use the property of a parabola that states that the tangent at any point on the parabola is perpendicular to the line segment joining that point to the focus. Since the focal chord is parallel to the directrix, the line segment joining the point of tangency to the focus will be equal in length for both tangents.
3. What is the significance of the tangents to the focal chord of a parabola?
The tangents to the focal chord of a parabola have equal length and intersect at the focus of the parabola. This property is useful in various applications, such as determining the maximum or minimum value of a function represented by a parabola.
4. Can you prove that tangents to the focal chord of a parabola are perpendicular to the directrix?
Yes, we can prove this by using the definition of a parabola. Since a parabola is defined as the set of all points that are equidistant from a fixed point (focus) and a fixed line (directrix), the tangents to the focal chord must be perpendicular to the directrix.
5. How does the focal chord of a parabola relate to its axis of symmetry?
The focal chord of a parabola is parallel to its axis of symmetry. This means that the line segment joining the focus and the midpoint of the focal chord is perpendicular to the axis of symmetry. This property is useful in finding the equation of a parabola when its focus and directrix are known.
