Prove that that every symmetric real matrix is diagonalizable?
In summary, it is a major theorem that every symmetric real matrix is diagonalizable, and its proof involves showing that self-adjoint linear transformations must have real eigenvalues and orthogonal eigenvectors corresponding to distinct eigenvalues. The matrix can then be written as a direct sum of diagonal matrices with the same eigenvalue, leading to a final diagonal matrix in an orthonormal basis.
complexhuman
How can I prove that that every symmetric real matrix is diagonalizable?
Thanks in advance
That's a MAJOR theorem so at best I can just outline the proof here.
The more general theorem is that every self-adjoint linear transformation is diagonalizable- and symmetric (real) matrices, thought of as linear transformations on Rn, are self- adjoint. A self-adjoint linear transformation is one such that
<Ax,y>= <x,Ay> where <x, y> is the innerproduct on the vector space.
First show that the eigenvalues of a self-adjoint linear transformation must be real:
If λ is an eigenvalue of A, take x to be a unit length eigenvector. Then λ= λ<x, x>= <λx,x>= <x, λx>= complexconjugate(λ)<x,x>= complexconjugate(λ). Since λ equals its complex conjugate, it is real.
Second, show that eigenvectors corresponding to distinct eigenvalues are orthogonal: If Ax= λx and Ay= μ y then λ<x, y>= <λx,y>= <Ax, y>= <x, Ay>= <x,μy>= μ<x,y> (since μ is real). Then (λ- μ)<x,y>= 0. Since λ and μ are distinct, we must have <x,y>= 0.
So: given any self-adoint linear transformation (or symmetric matrix) we can write the vector space as a direct sum of orthogonal subspaces, every vector of which is an eigenvector corresponding to the same eigenvalue. Choose any orthonormal basis for each subspace and show that the matrix for A, restricted to that subspace, is simply λI- a diagonal matrix with only λ on the diagonal.
Finally, the union of the orthonormal bases for each subspace will be an orthonormal basis for the entire space and the matrix corresponding to A in that basis is diagonal.
To prove that every symmetric real matrix is diagonalizable, we first need to understand the definitions of symmetric matrix and diagonalizable matrix.
A symmetric matrix is a square matrix where the elements are equal to their corresponding elements across the main diagonal. In other words, if A is a symmetric matrix of size n x n, then A[i,j] = A[j,i] for all i,j = 1,2,...,n.
A diagonalizable matrix is a square matrix that can be transformed into a diagonal matrix by a similarity transformation. In other words, if A is a diagonalizable matrix of size n x n, then there exists an invertible matrix P such that P^-1 * A * P = D, where D is a diagonal matrix.
Now, to prove that every symmetric real matrix is diagonalizable, we can use the Spectral Theorem for symmetric matrices. This theorem states that every real symmetric matrix can be diagonalized by an orthogonal matrix.
An orthogonal matrix is a square matrix whose columns and rows are orthogonal unit vectors. This means that the dot product of any two columns (or rows) of an orthogonal matrix is equal to 0, and the length of each column (or row) is equal to 1.
So, if we take a symmetric matrix A, we can find an orthogonal matrix P such that P^-1 * A * P = D, where D is a diagonal matrix. This is because the columns of P will be the eigenvectors of A, and since A is symmetric, its eigenvectors are orthogonal.
Therefore, every symmetric real matrix can be diagonalized by an orthogonal matrix, which means it is diagonalizable. This completes the proof.
FAQ: Prove that that every symmetric real matrix is diagonalizable?
What is a symmetric real matrix?
A symmetric real matrix is a square matrix where the elements are real numbers and the matrix is equal to its transpose.
What does it mean for a matrix to be diagonalizable?
A matrix is diagonalizable if it can be transformed into a diagonal matrix through a similarity transformation, where the diagonal matrix has the same eigenvalues as the original matrix.
Why is it important to prove that every symmetric real matrix is diagonalizable?
This proof is important because it allows us to better understand and manipulate symmetric matrices, which are commonly used in various fields of mathematics and science.
What is the process for proving that every symmetric real matrix is diagonalizable?
The proof involves showing that the matrix has a full set of eigenvectors that are linearly independent, and then using these eigenvectors to construct the diagonal matrix.
Can this proof be applied to other types of matrices?
Yes, similar proofs can be applied to other types of matrices, such as Hermitian matrices in complex numbers and normal matrices in any field.
