Prove that the following is a Topology. I really just want to clean it up.
In summary, the Homework Equations and DeMorgan's Laws will be useful in trying to solve the problem of proving that T1={U subset of X: X\U is finite or is all of X} is a topology. The Attempt at a Solution states that if X is empty, then T1 is the empty set, but if X does not include empty set, then T1 is X/empty set.
Hodgey8806
145
Prove that T1={U subset of X: X\U is finite or is all of X} is a topology.
DeMorgan's Laws will be useful.
Empty set is defined as finite, and X is an arbitrary infinite set.
1) X/X = empty set, finite. Thus X is in T1
2) X/empty set = X, infinite. Thus Empty Set is in T1
3) Let {Ua:a is in A} be a collection of sets in T1
Spse Ua ≠ X.
X\(indexed unionUa) = indexed intersection(X\Ua)
This is finite since each X\Ua is finite or is all of X. (element of T1)
Spse Ua = empty set for all a, then the indexed intersection(X\Ua) = X (element of T1)
Spse Ua-bar ≠ empty set for some a, then the indexed intersection(X\Ua) is a subset of X\Ua-bar (element of T1).
4) Let {Ua:a is in A} be a collection of sets in T1
Spse Ua ≠ empty set.
X\(indexed intersectionUa) = indexed union(X\Ua),
Since the number of intersection must be finite and X\Ua is finite for all a,
Then the union of finitely many finite sets is finite. (element of T1)
If Ua = empty set for some a,
Then the indexed union (X\Ua) is either finite or all of X. (element of T1)
I,m sorry, Idon't get what you're asking.
Actually, you are NOT given that X is infinite. But the point is that X/empty set is all of X.
Spse Ua ≠ X.
Hodgey,
(1.) & (2.) look fine.
I'll edit & make some comments below for the others.
For (3.):
Let [itex]\displaystyle
\left\{ \text{U}_\alpha\ :\ \alpha \in \text{A}\right\}[/itex] be an arbitrary collection of sets in T1 .
[STRIKE]Spse Ua ≠ X. [/STRIKE] (Not needed)
[itex]\displaystyle \text{X}\backslash \left(\bigcup\left(\text{U}_\alpha\right)\right)= \bigcap\left(\text{X}\backslash\text{U}_\alpha \right) [/itex]
If [itex]
\displaystyle \text{U}_\alpha = \emptyset \text{ for all }\alpha\in\text{A}\,,[/itex] then [itex]\displaystyle \bigcap\left(\text{X}\backslash\text{U}_\alpha \right)=\text{X}\ .[/itex]
Otherwise, argue that one of the [itex]\displaystyle \text{X}\backslash\text{U}_\alpha[/itex] is finite for some [itex]\displaystyle \text{U}_\alpha[/itex] ... so that the intersection is finite.
For (4):
This should be a finite intersection, so a finite collection of sets.​
Thank you very much! I understand this a bit better now. To me that piece didn't seem necessary, but we worked through it fast in class so I suppose it was there for good measure.
I argued on 3) that it is finite because if it intersects a finite set, the indexed intersection is now a subset of that particular finite set.
Thanks again! I have many more questions I need guidance on!
Related to Prove that the following is a Topology. I really just want to clean it up.
1. What is a topology?
A topology is a mathematical concept that describes the properties and relationships of a set of points. It is a way to define the structure of a space without relying on the notion of distance.
2. How do you prove that something is a topology?
To prove that something is a topology, you need to demonstrate that it satisfies three properties: it contains the empty set and the whole set, it is closed under finite intersections, and it is closed under arbitrary unions. These properties ensure that the topology defines a well-behaved space.
3. What does it mean to "clean up" a topology?
Cleaning up a topology refers to simplifying and organizing it in a way that makes it easier to understand and work with. This can involve removing redundant or unnecessary elements, clarifying definitions, or reorganizing the structure of the topology.
4. What are the benefits of a clean topology?
A clean topology can make it easier to see the relationships and properties of a space, allowing for more efficient and accurate mathematical reasoning. It can also make it easier to apply the topology to real-world problems or use it in conjunction with other mathematical concepts.
5. Are there any rules or guidelines for cleaning up a topology?
There are no strict rules for cleaning up a topology, as it can depend on the specific context and purpose of the topology. However, some general guidelines include removing redundant elements, organizing the topology in a logical way, and ensuring the definitions and properties are clear and consistent.
