Prove that the function given with f(x) is a PDF
  • Thread starter Thread starter MrKushtrim
    Function Pdf
MrKushtrim
Hi,
Could someone help me prove that the function given with
is a probability density function, where and
I thought to solve it somehow by using the binomial theorem, but since it's the upper part that's changing on the binomial coefficients, this proved futile.
Let's start simple:
Can you prove that the value is always larger than zero?
Use ## instead of $ for inline LaTeX.
MrKushtrim said:
Hi,
f(x) = \binom{x-1}{r-1} p^{r}(1-p)^{x-r} is a probability density function, where x= r, r+1,..., \infty and 0<p<1
You need to show that \sum_{x=r}^\infty \binom{x-1}{r-1} p^r (1-p)^{x-r} = 1. Setting q = 1- p and m = x - r gives <br /> \sum_{x=r}^\infty \binom{x-1}{r-1} p^r (1-p)^{x-r} <br /> = (1 - q)^r \sum_{m=0}^\infty \frac{(m + r - 1)!}{(r-1)!m!}q^m. What does the series on the right have to equal if the left hand side is to equal 1, and can you prove that it does?
MrKushtrim said:
Hi,
$f(x) = \binom{x-1}{r-1} p^{r}(1-p)^{x-r}$ is a probability density function, where $x= r, r+1,..., \infty $ and $0<p<1$
For discrete random variables, I prefer to use symbols like and instead of . So, in this notation: what properties must be possessed by
f_k = {k-1 \choose r-1} p^r (1-p)^{k-r}, \, k = r, r+1, r+2, \ldots
in order that it be a legitimate probability mass function of a discrete random variable? Note that is NOT a probability density function; it is a probability mass function. There is a world of difference!
Hi, thanks for the reply .
It must equal 1. Though I have no idea how to prove it.
Ray Vickson said:
For discrete random variables, I prefer to use symbols like ##j## and ##k## instead of ##x##. So, in this notation: what properties must be possessed by
in order that it be a legitimate probability mass function of a discrete random variable? Note that ##f_k## is NOT a probability density function; it is a probability mass function. There is a world of difference!
Thanks, I had the terminology mixed up.
To be a probability mass function , has to be positive, and the sum over all has to be 1.
It's easy to see that is positive, but I cannot seem to prove the second property
Remember, you need to show that
<br /> (1 -q)^r \sum_{m=0}^\infty \frac{(m + r - 1)!}{(r-1)!m!}q^m = 1<br /> for every 0 &lt; q &lt; 1. This suggests that the series \sum_{m=0}^\infty \frac{(m + r - 1)!}{(r-1)!m!}q^m must be the binomial expansion of ... what function of q?
Likes 1 person
But how would I prove that ?
Edit:
I checked a wikipedia article about binomial series, and it turns out that the series \sum_{m=0}^\infty \frac{(m + r - 1)!}{(r-1)!m!}q^m is of this form , where and
Thanks for the help :)
Though, is there any other way to prove it, without directly using the formula ?
MrKushtrim said:
## \frac{1}{(1 -q)^r } ##
Edit:
I checked a wikipedia article about binomial series, and it turns out that the series \sum_{m=0}^\infty \frac{(m + r - 1)!}{(r-1)!m!}q^m is of this form , where ##β= r-1## and ##z=q##
Ultimately the only way to sum power series is to relate them to power series of known functions.
There are other ways of showing that \sum_{m=0}^\infty \frac{(m + r - 1)!}{(r-1)!m!}q^m = (1 - q)^{-r}. For example, using the formula <br /> \frac{d^k}{dx^k} \left( \sum_{n=0}^\infty a_n x^n \right) <br /> = \sum_{n=0}^\infty a_{n+k} \frac{(n + k)!}{n!} x^n we see that <br /> \sum_{m=0}^\infty \frac{(m + r - 1)!}{(r-1)!m!}q^m = \frac{1}{(r - 1)!} \frac{d^{r-1}}{dq^{r-1}} \left( \sum_{m=0}^\infty q^m \right). \sum_{m=0}^\infty q^m is a geometric series and is easily summed.
