I Prove that the geometric mean is always the same
The discussion focuses on proving that the geometric mean of distances from a point P to points on a circle remains constant regardless of the orientation of lines intersecting the circle. It highlights the relationship established by the Intersecting Chords Theorem, which states that the product of the segments created by two intersecting chords is equal. The participants explore the implications of this theorem and how it relates to the geometric mean of distances from point P to points on the circle. A GeoGebra model is referenced to visualize the concept, and a user expresses gratitude for discovering the theorem after previously searching with less effective terms. The conversation emphasizes the significance of understanding geometric relationships in proving mathematical concepts.
Trysse
Given are a fixed point ##P## and a fixed circle ##c## with the radius ##r##. Point ##P## can be anywhere inside or outside the circle. I now draw two arbitrary lines ##l_1## and ##l_2## through the point ##P## in such a way, that both lines intersect with the circle ##c## in two distinct points. I name the points ##C_1## and ##C_2## for the line ##l_1##, respectively ##C_3## and ##C_4## for the second line ##l_2##. This gives me two sets of distances. For ##l_1## these are the distances ##PC_1## and ##PC_2##. For ##l_2## these are the distances ##PC_3## and ##PC_4##
For reference see the GeoGebra model: https://www.geogebra.org/classic/xvgereug
According to the GeoGebra model, the product of the two distances always has the same value for a given point ##P## and a given circle ##c## regardless of the orientation of the two lines.
$$PC_1 \cdot PC_2 = PC_3 \cdot PC_4$$
If I draw the line ##l_1## in such a way, that the distances ##PC_1=PC_2## this length is the square root of any two distances ##PC_3## and ##PC_4##. I.e.,
$$PC_1=PC_2 \Rightarrow PC_1=\sqrt {PC_3 \cdot PC_4}$$
So I have two questions:
1)
How can I prove, that the geometric mean (or the product) of the two distances ##PC_1## and ##PC_2## is always the same for any line through the point ##P## that intersects the circle ##c## in two points?
2)
I was thinking, that the value of the geometric mean of these two distances is somehow the geometric mean of all distances the point ##P## has to all points that lie on the circle ##c##. However, I found this post on StackExchange that argues otherwise. My intuitive approach was to calculate the following:
$$\sqrt[4] {PC_1 \cdot PC_2 \cdot PC_3 \cdot PC_4}$$
As I add ever more lines ##l_n## so I get more distances ##PC_{2n-1}## and ##PC_{2n}## that I can add in pairs to calculate the geometric mean, the result will always be the same. What is wrong with my approach? For the StackExcnage post, see here:
https://math.stackexchange.com/ques...stances-from-point-to-every-point-on-a-circle
In the Geogebra model, you can set the point ##P## with drag-and-drop and then change the lines' orientation by moving the pink points.
This is not homework.
Mathematics news on Phys.org
What you are trying to prove is the "Intersecting Chords Theorem". There's a nice, short, simple proof here.
The result follows from demonstrating that triangles ##PC_1C_4## and ##PC_3C_2## are similar, because angles on the circle at the circumference standing on the same chord are equal.
Likes BvU, hutchphd, jim mcnamara and 1 other person
@andrewkirk thanks. That is what I was looking for.. I would have never found this theorem on Google. I was always searching for "geometric mean, & circle & proof" but never for "chords".... Thanks for pointing me in the right direction.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
