Prove that the limit of a sequence exists
In summary: Ok fine , one last question from me, ##N## is not exactly a constant (like ##x_1##) but it depends on ##\epsilon##. It might be the case that as ##\epsilon \rightarrow 0## that ##N\rightarrow \infty## and this leads to a problem (cause we will have as ##n\rightarrow \infty, \frac{Nx_1}{n}\rightarrow \frac{\infty}{\infty}##).I believe in order to complete the proof, we should prove that ##N=N(\epsilon)\leq c## for some constant...any ideas?i think it would be like this: as n tends to infinity, since lim xn
shrub_broom
suppose that 0≤xm+n≤xm+xn for all m,n∈ℕ, prove that the limit of xn/n exists when n tends to infinity.
I get that xn is bounded by zero and x1. And I guess that xn is monotonous but i find it hard to prove. Or maybe there is another way to prove the existence of this limit.
Perhaps it is just a typo, but ##x_n## is not bounded above by ##x_1##. It isn't bounded above at all. Think about the sequence ##x_n = n##. It satisfies all the conditions and you have ##\frac {x_n} n \to 1##. That seems like a worst case sequence, but I don't have anything further for you at the moment. Not too helpful I know...
Well, since for each m∈ℕ, we get -
well i just made a mistake. and i want to mean xn/n is bounded by x1. sorry for that fault
the sequence is not monotonous. Let x2n=a and x2n+1=b; a≤b≤2a.
You are correct, the sequence is not monotonous (boring). It is also not monotone. :oldsmile:
Hi shrub and LC:
I am confused by the conclusion that the series is not monotonic. What is the rational for this conclusion from the statement
(1) x2n=a and x2n+1=b; a≤b≤2a?​
Even when adding the PO requirement
(2) 0≤xm+n≤xm+xn
I do not see this conclusion as valid.
Suppose we define
xn = n.​
This is a monotonic sequence that satisfied both (1) and (2).
Using (1)
2n ≤ 2n+1 ≤ 4n.​
Using (2)
m + n ≤ m + n.​
Regards,
Buzz
From the given inequality for ##m=n+1## we have that $$x_{n+1}\leq x_n+x_1 \Rightarrow \frac{x_{n+1}}{n+1}\leq \frac{x_n+x_1}{n+1}\leq \frac{x_n}{n}+\frac{x_1}{n}$$, so for the sequence ##y_n=\frac{x_n}{n}## we have that $$y_{n+1}\leq y_n+\frac{x_1}{n}$$.
Now this is equivalent to say that "for any ##\epsilon>0## there exists ##n_0\geq \frac{x_1}{\epsilon}## such that for ##n\geq n_0##, ##y_{n+1}\leq y_n+\epsilon##", so ##y_n## is not exactly monotonous it is something like monotonous in a neighbourhood of +infinity
Hope that helps.
i get a proof. suppose that the limit inferior of the sequence is a, and then prove that the limit superior is no greater than a. to prove so, for any positive ε, there exist N xN/N ≤ a+ε. and for any n∈ℕ∧n≥N, we have n =p N+q p,q∈ℕ and q is less than N. hence, xn=xpN+q≤pxN+N x1; xn/n≤a+ε+Nx1/n. when n tends to infinity, since N, x1 are limited, we get that the limit superior is no greater than its limit inferior. hence the sequence is converge.
Buzz Bloom said:
Hi shrub and LC:
(2) 0≤xm+n≤xm+xn
Suppose we define
xn = n.​
Using (1)
2n ≤ 2n+1 ≤ 4n.​
Using (2)
m + n ≤ m + n.​
Regards,
Buzz
for any m,n. xm+n≤xm+xn since a≤2b. if divide the right side,it becomes greater and the inequality is still true.
what happens to ##p##? Shouldn't it be ##\frac{x_n}{n}\leq p(a+\epsilon)+\frac{Nx_1}{n}## but as n tends to infinity, p tends to infinity also...
i think it should be ##\frac{x_n}{n}\leq\frac{px_N+qx_1}{pN+q}\leq
\frac{x_N}{N}
+\frac{Nx_1}{n}##
Likes Delta2
\frac{x_N}{N}
+\frac{Nx_1}{n}##
I believe in order to complete the proof, we should prove that ##N=N(\epsilon)\leq c## for some constant ##c##.
Exactly i think there is no need to prove this hypothesi.Write the right of the inequality in the form of defination we get ##a+\eplison+frac{Nx_1}{n}##. Although N is determined by##\eplison##, if we choose a big enough ##p##, then##\frac{Nx_1}{n}##can be any positive real number, which means ##\eplison+frac{Nx_1}{n}## can also be any positive real number. And this is the defination of the Iimit.
Exactly i think there is no need to prove this hypothesi.Write the right of the inequality in the form of defination we get ##a+\epsilon+\frac{Nx_1}{n}##. Although N is determined by##\epsilon##, if we choose a big enough ##p##, then##\frac{Nx_1}{n}##can be any positive real number, which means ##\epsilon+frac{Nx_1}{n}## can also be any positive real number. And this is the defination of the Iimit.
shrub_broom said:
Exactly i think there is no need to prove this hypothesi.Write the right of the inequality in the form of defination we get ##a+\epsilon+\frac{Nx_1}{n}##. Although N is determined by##\epsilon##, if we choose a big enough ##p##, then##\frac{Nx_1}{n}##can be any positive real number, which means ##\epsilon+\frac{Nx_1}{n}## can also be any positive real number. And this is the defination of the Iimit.
Well, I still forget to correct some typo.
Likes Delta2
I think you are right after all. We can choose ##n## (or ##p## as you say) as big as we want (for example ##n=N^2##), and thus ##\frac{Nx_1}{n}## can become as small as we want.
Hi shrub:
I think I now understand my confusion, but since I am not sure, I would much appreciate your response.
There are two being discussed: xn and xn/n.
In my post #6, I thought your statement in post #4
referred to the sequence xn in a general way, and I believe this sequence may or may not be monotonic. However,I now think you meant that the sequence xn/n is not monotonic. Is this correct?
Regards,
Buzz
Buzz Bloom said:
Hi shrub:
Regards,
Buzz
yes, the xn/n is not monotonous
Related to Prove that the limit of a sequence exists
1. What is the definition of a limit of a sequence?
The limit of a sequence is the value that the terms of the sequence approach as the input values approach a certain value, typically infinity. In simpler terms, it is the value that the sequence "converges" to.
2. How do you prove that the limit of a sequence exists?
To prove that the limit of a sequence exists, you must show that the terms of the sequence get closer and closer to a specific value as the input values approach a certain value. This can be done through various methods such as the epsilon-delta definition, the squeeze theorem, or using the Monotone Convergence Theorem.
3. What is the epsilon-delta definition of a limit of a sequence?
The epsilon-delta definition of a limit states that for a given value ε (epsilon), there exists a corresponding value δ (delta) such that if the input values are within a distance of δ from the limit value, then the output values will be within a distance of ε from the limit value.
4. Can the limit of a sequence exist if the terms of the sequence are not approaching a specific value?
No, the limit of a sequence can only exist if the terms of the sequence are approaching a specific value. If the terms of the sequence are not approaching a specific value, then the sequence is said to diverge and the limit does not exist.
5. Are there any special cases where the limit of a sequence may not exist?
Yes, there are certain special cases where the limit of a sequence may not exist. This can occur if the terms of the sequence alternate between two values or if the terms of the sequence continue to increase or decrease without approaching a specific value. In these cases, the limit does not exist.
