I Prove that the limit of this matrix expression is 0
lriuui0x0
Given a singular matrix ##A##, let ##B = A - tI## for small positive ##t## such that ##B## is non-singular. Prove that:
\lim_{t\to 0} (\chi_A(B) + \det(B)I)B^{-1} = 0
where ##\chi_A## is the characteristic polynomial of ##A##. Note that ##\lim_{t\to 0} \chi_A(B) = \chi_A(A) = 0## by Cayley-Hamilton theorem.
This limit involves the product of a convergent to zero function and a divergent function. I'm not sure how to transform the limit in order to prove this.
In wikipedia characteristic polynomials
We consider an n×n matrix A. The characteristic polynomial of A, denoted by pA(t), is the polynomial defined by[5]
{\displaystyle p_{A}(t)=\det \left(tI-A\right)}
where I denotes the n×n identity matrix.
Wiki says parameter of characteristic polynomial t a number though you say it B, a matrix. I am confused.
Yes, it's passing in the matrix into the polynomial. Please check Cayley-Hamilton theorem.
Likes anuttarasammyak
I don't know how to tackle the problem, but here are some ideas:
  • proof by induction
  • replacing ##B^{-1}=\dfrac{1}{A-tI}## by its series
  • using the Jordan normal form
  • the limit has to be taken for every matrix entry, so maybe choosing a single one could simplify the problem
Let \chi_A(x) = \sum_{n=0}^N a_nx^n. Then <br /> (\chi_A(B) + \det(B)I)B^{-1} = (a_0 + \det B)B^{-1} + \sum_{n=0}^{N-1} a_{n+1}B^{n}. Recall that B^{-1} = \frac{\operatorname{adj}(B)}{\det(B)} where \operatorname{adj}(B) is the adjugate matrix of B, and that a_0 vanishes as A is singular. This shows that the limit is finite; there is more to do to show that it vanishes.
EDIT: We also have the identity (stated here) <br /> \operatorname{adj}(-A) = \sum_{n=0}^{N-1} a_{n+1}A^n and thus <br /> \lim_{t \to 0} (\chi_A(B) + \det(B)I)B^{-1} = \operatorname{adj}(A) + \operatorname{adj}(-A) = (1 + (-1)^{N-1})\operatorname{adj}(A) which is either 2\operatorname{adj}(A) or 0 depending on whether N is odd or even.
Thanks for the help!
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
