Prove that the linear space is infinite dimensional
In summary: Oh! ##\cos2x## is not a linear combination of cos x and sin x, it involves product of elements.Yes, all of those trig functions are independent.Since, we can find as many independent elements in S as we like, therefore, S doesn't have a basis of any fixed number of elements.In summary, the first problem involves finding an infinite sequence of linearly independent elements for the space of all sequences whose limit is zero, which is possible by constructing sequences similar to the basis of ##\mathbb{R}^n##. For the second problem, the key is to find an infinite set of linearly independent functions, and this can be achieved by using trigonometric functions with specific powers (
Hall
351
88
Prove that the Linear space of all sequences whose limit is zero is infinite dimensional. (And one more).
Infinite dimension means having an infinite basis.
A space is infinite dimensional when its basis is infinite. But how can I ensure that the basis of the space of all sequences whose limit is zero is infinite?
(After solving that, I would like to have a hint on this very similar problem which says: let V be a Linear space of all continuous functions in the interval ##[-\pi, \pi]##. Let S be the subset of V which contain all those functions which satisfy:
1. $$ \int_{-\pi}^{\pi} f dt =0$$
2. $$ \int_{-\pi}^{\pi} f \cos t dt =0$$
3. $$ \int_{-\pi}^{\pi} f \sin t dt =0$$
Prove that S is infinite dimensional.)
You don't need to find a basis which is infinite (what that even means is a little tricky). You just have to find an infinite sequence of linearly independent elements. For the set of sequences whose limit is 0, this is pretty easy actually - you have something that kind of looks like ##\mathbb{R}^{\infty}##.
Likes FactChecker and PeroK
All right, that idea is clear to me.
I find myself unable to do that. Can you give me a little example?
Hall said:
All right, that idea is clear to me.I find myself unable to do that. Can you give me a little example?
If I asked you to give me linearly independent elements of ##\mathbb{R}^n## for large n, what would you say?
Likes FactChecker
(1,0,0,0,\cdots 0), (0,1,0,0\cdots 0), \cdots, (0,0,0,0, \cdots 1) \}$$
Can you make those into linearly independent sequences?
I'm not very sure, but
1, 0,0,0 \cdots 0$$
0,1,0,0 \cdots 0$$
##\cdots##
$$0,0,0 \cdots 0$$
Are sequences with limit zero and they are independent (in the sense that one cannot be born no matter how the rest of them breed).
1, 0,0,0 \cdots 0$$
0,1,0,0 \cdots 0$$
##\cdots##
$$0,0,0 \cdots 0$$
So, that's ##n## linearly independent sequences. And, ##n## is arbitrary, therefore ...
Likes Hall
Can we construct any sequence with limit zero from them?
(Can we move to the second problem?)
We don't need to try to prove that. We don't need to find a basis; simply an infinite set of linearly independent sequences.
The key here must be harmonic functions.
The idea here is that if a vector space has a finite dimension ##n##, you can have at most ##n## linearly independent vectors in a set of vectors. Since you found an infinite set of independent vectors, what does that imply?
Likes Hall and PeroK
For the second problem, I went for the same idea, i.e. finding infinite number of independent elements, but I could find only four functions that are independent and belong to ##S##: ##f=0##, ## f = t^{(2n-1)}##, ## f= \cos nx##, and ##f= \sin nx## (where n represents a natural number).
Can ##n## be any natural number?
Yes.
Hall said:
Yes.
So... How many choices of n are there?
How many different functions have you actually found?
Hall said:
Yes.
So, you have an infnite number of such functions. Can you prove that any finite set are linearly independent?
0, ##t##, ##t^3##, ##t^5## ##\cdots##, ##\cos x##, ##\cos 2x##, ##\cos 3x## ##\cdots##, ##\sin x##, ##\sin 2x##, ##\cdots##
Proving these are independent is not easy. Just because cos(2x) can be expressed as a sum of products of sin(x) and cos(x), doesn't mean there isn't a more clever way to write it down that's a linear combination.
The orthogonal condition in the op is actually the typical way to prove these are all linearly independent. For example
If ##\cos(2x)=a\sin(x)+b\cos(x)##, we have
$$0<\int_{-\pi}^{\pi} \cos^2(2x) dx = a\int_{-\pi}^{\pi} \sin(x) \cos(2x)dx + b \int_{-\pi}^{\pi} \cos(x) \cos(2x) dx=0$$
Likes Hall
What about an induction on ##n##? Using the second derivatives of ##\cos(kx)##:
$$A_1\cos(x) + A_2\cos(2x) + \dots + A_n\cos(nx) = 0$$$$ \Rightarrow A_1\cos(x) + 4A_2\cos(2x) + \dots + n^2A_n\cos(nx) = 0$$$$ \Rightarrow \ (n^2 - 1)A_1\cos(x) + (n^2 - 4)A_2\cos(2x) + \dots + (n^2 - (n-1)^2)A_{n-1}\cos((n-1)x) = 0$$
Likes Hall
FAQ: Prove that the linear space is infinite dimensional
What is a linear space?
A linear space, also known as a vector space, is a mathematical structure that consists of a set of elements, called vectors, and two operations (addition and scalar multiplication) that satisfy certain properties. These properties include closure, associativity, commutativity, distributivity, and the existence of an identity element.
How do you prove that a linear space is infinite dimensional?
To prove that a linear space is infinite dimensional, we must show that it contains an infinite number of linearly independent vectors. This means that no vector in the space can be written as a linear combination of a finite number of other vectors. If we can find an infinite linearly independent set of vectors in the space, then we can conclude that the space is infinite dimensional.
What is the difference between finite and infinite dimensional linear spaces?
A finite dimensional linear space has a finite basis, meaning that it can be spanned by a finite number of linearly independent vectors. On the other hand, an infinite dimensional linear space has an infinite basis, meaning that it cannot be spanned by a finite number of vectors. This means that infinite dimensional spaces have more vectors and more possible combinations of vectors than finite dimensional spaces.
Can a linear space be both finite and infinite dimensional?
No, a linear space can only be either finite or infinite dimensional. This is because the dimension of a linear space is defined as the number of vectors in its basis. If the basis is finite, then the space is finite dimensional. If the basis is infinite, then the space is infinite dimensional.
Why is it important to prove that a linear space is infinite dimensional?
Proving that a linear space is infinite dimensional is important because it allows us to understand the structure and properties of the space better. It also helps us to determine the number of linearly independent vectors in the space, which can be useful in solving problems in linear algebra and other areas of mathematics.
