Prove the equation has no real solution
  • MHB
  • Thread starter anemone
In summary: You're welcome! I really enjoy these challenges and I'm happy to participate. Your solutions are always so clear and easy to understand. Keep them coming! :)
anemone
MHB
POTW Director
3,883
115
Prove that the polynomial equation $x^8-x^7+x^2-x+15=0$ has no real solution.
Mathematics news on Phys.org
[sp]Let $f(x) = x^8-x^7+x^2-x = (x-1)(x^7 + x)$. If $x<0$ then both factors are negative and so $f(x)>0$. If $x>1$ then both factors are positive and so $f(x)>0$ again. If $0\leqslant x \leqslant 1$ then $|x-1|\leqslant 1$ and $|x^7+x|\leqslant 2$ and so $f(x) \geqslant -2$. Thus $f(x) \geqslant -2$ for all real $x$ and so $f(x) + 15 \geqslant 13 >0$. Hence $f(x) + 15 = 0$ has no real roots.[/sp]
Thanks for participating, Opalg and welcome back to the forum! You have not been posting much lately and we have certainly missed you.(Sun)
Hello.
[tex]y=x^8-x^7+x^2-x+15[/tex]
[tex]y'=8x^7-7x^6+2x-1=0[/tex]
[tex]x_0 \approx{ }0.53079[/tex](unique real solution)
[tex]y''=56x^6-42x^5+2[/tex]
[tex]For \ x_0 \approx{ }0.53079 \rightarrow{ }y'' \approx{ }1.48279 \rightarrow{ }x_0 \ it's \ minimum[/tex]
[tex]y_0 \approx{ }14.7453 \rightarrow{}y \cancel{=} \ 0 \ (never)[/tex]
Regards.
mente oscura said:
Hello.
Regards.
Hey mente oscura, thanks for participating and yes, your approach works as well! Well done!:)
$\bf{Solution::}$ Let $f(x) = x^8-x^7+x^2-x+15$, we check real solution in $\bf{x\in \mathbb{R}}$
$\bullet$ If $x\leq 0$, Then $f(x) = x^8-x^7+x^2-x+15>0$
$\bullet$ If $0<x<1$, Then $f(x) = x^8+x^2(1-x^5)+(1-x)+14>0$
$\bullet$ If $x\geq 1$, Then $f(x)= x^7(x-1)+x(x-1)+15>0$
So we observe that $f(x)= x^8-x^7+x^2-x+15>0\;\forall x\in \mathbb{R}$
So $f(x)=x^8-x^7+x^2-x+1=0$ has no real roots for all $x\in \mathbb{R}$
- - - Updated - - -
**Another Solution::**
If $x<0,$ note that $x^8+(-x^7)+x^2+(-x)>0,$ so the polynomial cannot have any negative roots.If $x\geq 0,$ then note that from AM-GM inequality we have:
$\left\{\begin{aligned}& \frac 78 x^8+\frac 18\geq x^7\\& x^2+\frac 14\geq x\end{aligned}\right\} ;$
Thus $\displaystyle\frac 78x^8-x^7+x^2-x+\frac 38>0;$
- - - Updated - - -
Hey jacks, thanks for participating and it's so nice to see so many people answered to my challenge problem!:eek:
FAQ: Prove the equation has no real solution
What does it mean for an equation to have no real solution?
When an equation has no real solution, it means that there are no values for the variable(s) that make the equation true. In other words, the equation has no solution that can be expressed as a real number.
How can I determine if an equation has no real solution?
One way to determine if an equation has no real solution is by graphing the equation and seeing if the graph intersects the x-axis. If the graph does not intersect the x-axis, then the equation has no real solution. Another way is to use the discriminant formula, which is part of the quadratic formula, to see if the discriminant is negative. If the discriminant is negative, then the equation has no real solution.
Can an equation have both real and imaginary solutions?
Yes, an equation can have both real and imaginary solutions. This typically happens when the equation contains complex numbers or involves taking the square root of a negative number.
Are there any types of equations that are guaranteed to have no real solutions?
Yes, equations that involve taking the square root of a negative number, such as x2 = -1, will always have no real solutions. Additionally, equations with complex numbers in them, such as (2+3i)x = 5, will also have no real solutions.
What is the significance of proving that an equation has no real solution?
Proving that an equation has no real solution can be important in determining the behavior of a mathematical system. It can also help in finding the complex solutions of an equation, which may be necessary for certain applications. Additionally, proving that an equation has no real solution can also help in understanding the limitations of the real number system.
