Prove the given hyperbolic trigonometry equation
chwala
See attached.
trigonometry- Further Maths
I have,
Using ##\ cosh 2x = 2 \cosh^2 x - 1##
##\cosh x = 2 \cosh^2\dfrac{x}{2} -1##
Therefore,
##\cosh x -1 = 2 \cosh^2\dfrac{x}{2} -1 - 1##
##\cosh x -1 = 2 \cosh^2\dfrac{x}{2} -2##
##=2\left[ \cosh^2 \dfrac{x}{2} -1 \right]##
##= 2\left[\left(\dfrac{(e^\frac{x}{2} + e^\frac{-x}{2})}{2}\right)^2-1\right] ##
##= 2\left[\dfrac{(e^\frac{x}{2} + e^\frac{-x}{2})^2}{4}-1\right] ##
##= 2\left[\dfrac{(e^\frac{x}{2} + e^\frac{-x}{2})^2-4}{4}\right] ##
##= \dfrac{1}{2}\left[ e^x +e^{-x}-2 \right]##
##= \dfrac{1}{2}\left[ e^{0.5x}e^{0.5x} +e^{-0.5x}e^{-0.5x}-e^{0.5x}e^{-0.5x}-e^{0.5x}e^{-0.5x} \right]##
##= \dfrac{1}{2}\left[ e^{0.5x}(e^{0.5x}- e^{-0.5x})+ e^{-0.5x}(e^{-0.5x}-e^{0.5x}) \right]##
##= \dfrac{1}{2}\left[ e^{0.5x}(e^{0.5x}- e^{-0.5x})- e^{-0.5x}(e^{0.5x}-e^{-0.5x}) \right]##
##= \dfrac{1}{2}\left[ e^{0.5x}-e^{-0.5x}\right]^2##
I know that there could be a better straightforward approach...your insight is welcome.
Typos in your exponents. Right now you have zero at the very end. Explain the 5th equality from the bottom.
I'll amend the last line...the other steps are straightforward.
chwala said:
Homework Statement: See attached.
Relevant Equations: trigonometry- Further Maths
I have,
You need to end up with \sinh^2 \frac x2, so start from \cosh 2x - 1 = 2\sinh^2 x. But using these identities comes very close to assuming exactly what the question is asking you to show.
In any event, the simplest approach is the straight forward \begin{split}<br /> (e^{x/2} - e^{-x/2})^2 &amp;= (e^{x/2})^2 - 2(e^{x/2})(e^{-x/2}) + (e^{-x/2})^2 \\<br /> &amp;= e^{x} - 2 + e^{-x} \\<br /> &amp;= 2\cosh x - 2.\end{split}
Likes SammyS and chwala
Yeah using ##\sinh^2 \dfrac{x}{2}## is easier...and the appropriate approach...has only 2 lines...will post that later...
Using,
##\cosh x = 2\left(1 + \sinh^2 \left( \dfrac{x}{2}\right) \right)-1##
##\cosh x = 2+2 \sinh^2 \left(\dfrac{x}{2}\right) -1= 2 \sinh^2 \left(\dfrac{x}{2} \right)+1##
Therefore
##\cosh x - 1 = 2 \sinh^2 \left(\dfrac{x}{2}\right)##
##\cosh x - 1 = 2\left[\dfrac{(e^{0.5x} - e^{-0.5x})}{2}\right]^2 = \left[\dfrac{(e^{0.5x} - e^{-0.5x})^2}{2}\right]##
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
