MHB Prove the inequality (a^3-c^3)/3≥abc((a-b)/c+(b-c)/a)
  • Thread starter Thread starter lfdahl
    Inequality
The inequality (a^3 - c^3)/3 ≥ abc((a - b)/c + (b - c)/a) is to be proven for non-zero real numbers a, b, and c, with the condition a ≥ b ≥ c. The discussion highlights a clever solution provided by a participant, which has garnered appreciation. The participants are also interested in the conditions under which equality holds in this inequality. Overall, the focus remains on proving the inequality and understanding the equality case.
lfdahl
MHB
Let $a, b$ and $c$ be non-zero real numbers, and let $a\ge b \ge c$. Prove the inequality:
$$\frac{a^3-c^3}{3} \ge abc\left(\frac{a-b}{c}+\frac{b-c}{a}\right)$$
When does equality hold?
Source: Nordic Math. Contest
Mathematics news on Phys.org
because $a >= b$ so $(a-b)>0$ or $(a-b)^3>= 0$ or $a^3-3a^2b+3ab^2-b^3>=0$
or $a^3-b^3 >= 3ab(a-b)$
similarly $b^3-c^3 >=3bc(b-c)$
adding we $a^3 -c^3 >= 3abc(\frac{a-b}{c}+\frac{b-c}{a})$
dividing both sides by 3 we get the result
they are equal if a=b =c
rationale
equal if $(a-b)^3 + (b-c)^3 = 0$ sum of 2 non negative numbers when each is zero
So simple... (Bow)
-Dan
Thankyou, kaliprasad for a clever solution. (Clapping)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
