- #36
Karol
- 1,380
- 22
$$\frac{(n+1)!}{(k+1)![(n+1)-(k+1)]!}=\frac{N!}{K!(N-K)!}=\frac{n!}{k!(n-k)!}=\frac{n!}{(k!)^2}$$
No, again you did not think it through thoroughly. Also, what you wrote down in the end is not what you have to prove (because it is false!). There should be a ##k## and not a ##k+1## in the binomial coefficient as well as in the derivative of ##v##. You just want the implication of the theorem being true for ##n## meaning that it is true for ##n+1## - ##k## is a summation variable and does not play a role - nothing says that you should change the way ##k## appears.Karol said:$$\frac{(n+1)!}{(k+1)![(n+1)-(k+1)]!}=\frac{N!}{K!(N-K)!}={n+1 \choose k+1}$$
$$\frac{d^{n+1}(uv)}{dx^{n+1}}=u^{n+1}v+\sum_{k=0}^{n-1} \left( \begin{array}{m} n+1\\k+1 \end{array} \right) u^{n-k}v^{k+1}+uv^{n+1}$$
But i have to prove:
$$\sum_{k=0}^n \left( \begin{array}{m} n\\k \end{array} \right) u^{n-k}v^k\ \ \rightarrow\ \ \sum_{k=0}^{n+1} \left( \begin{array}{m} n+1\\k+1 \end{array} \right) u^{n+1-k}v^{k+1}$$
If i substitute k=0 the first term in the sum gives ##~{n+1 \choose 1}~## and doesn't equal 1, as needed
You got this (I suppose) by splitting the sum into two sums and taking out the k = 0 term from the first, and the k = n term from the second, then you shifted the index in the first sum so that you could combine them into one sum.Karol said:$$\frac{d^{n+1}(uv)}{dx^{n+1}}=\left[ \sum_{k=0}^n \left( \begin{array}{m} n\\k \end{array} \right) u^{n-k}v^k \right]'=\sum_{k=0}^n \left( \begin{array}{m} n\\k \end{array} \right) (u^{n+1-k}v^k+u^{n-k}v^{k+1})$$
$$=u^{n+1}v+\sum_{k=0}^{n-1} \left[ \left( \begin{array}{m} n\\k \end{array} \right) + \left( \begin{array}{m} n\\k+1 \end{array} \right) \right] u^{n-k}v^{k+1}+uv^{n+1}$$
... becauseKarol said:Why do i need to expand ##~\left ( a^{1}b^{0}+a^{0}b^{1}\right) ^{n}~## and not just (a+b)n?
Why do i need ##~(D^{0}uD^{1}v+D^{1}uD^0{v})^{n}~## and not just ##~(D^{1}u+D^{1}v)^{n}~##?
$$(D^{1}u+D^{1}v)^{n}=\sum ^{n}_{i=0}\binom {n} {i}D^iu D^{n-i}v$$
