MHB Prove the minimum is greater than or equal to 8
  • Thread starter Thread starter anemone
    Minimum
The inequality problem involves proving that for positive reals \(a\), \(b\), and \(c\) satisfying \((a+2)(b+2)(c+2)=27\), it holds that \((a^2+1)(b^2+1)(c^2+1) \ge 8\). A key insight is that due to cyclic symmetry, the extremum occurs when \(a = b = c = 1\), yielding \((1^2+1)^3 = 8\). Testing other values, such as \(a = b = 2\) and \(c = 4.75\), shows that the product exceeds 8, confirming the inequality. The discussion highlights the challenge of the problem and the eventual realization that symmetry simplifies the proof. The conclusion is that the minimum value of the expression is indeed greater than or equal to 8.
anemone
MHB
POTW Director
Hello MHB!
Let $a,\,b$ and $c$ be positive real such that $(a+2)(b+2)(c+2)=27$. Prove that $(a^2+1)(b^2+1)(c^2+1)\ge 8$.
I've recently encountered the above really hard and good inequality problem that I failed to prove, I've been trying it for days but ALL my attempts proved futile.:mad: I feel completely defeated, and hope to get some useful hints to solve it from MHB...
Thanks in advance for the help!
Mathematics news on Phys.org
anemone said:
Hello MHB!
Because of cyclic symmetry we can see that extremum is ar a = b= c
this gives $(a+2)^3 = 27$ or a = 1 so a = b = c = 1
now $(a^2+1)(b^2+1)(c^2 +1) = 8$
taking a = b = 2 we get c = 4.75 and $(a^2+1)(b^2+1)(c^2+1) = 5 * 5 * (4.75^2+1) > 8$ and hence the result
Thanks kaliprasad...that advice does help!:)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
