Prove the shortest distance between two points is a line
In summary, the distance between the endpoints of an arclength parametrized curve can at most be L, and equality can only hold when the curve is a straight line segment. This is shown by using the properties of an arclength parameterized curve and the calculus of variations. Therefore, the shortest path between two points is the straight line segment connecting them.
MxwllsPersuasns
101
Let γ : [0, L] → Rn be arclength parametrized. Show that the distance between the endpoints of the curve can at most be L, and equality can only hold when γ is a straight line segment. Thus, the shortest path between two points is the straight line segment connecting them.
I guess maybe arclength: s(t) = ∫ ||γ'(t')||dt' from 0 to t
So my attempt would be to include the properties of an arclength parameterized curve; Namely that the length of such a curve is 1. Such that when you compute the arc length you get something like ∫1dt' from 0 to t (or in this specific case 0 to L) this tells us the length is L but I don't know how to prove that the equality holds only when its a straight line. Any suggestions?
*cough* Calculus of variations *cough*
Likes FactChecker
Related to Prove the shortest distance between two points is a line
What does it mean to prove the shortest distance between two points is a line?
Proving the shortest distance between two points is a line means demonstrating that the most direct path between two points is a straight line. This is a fundamental concept in geometry and is known as the shortest distance postulate.
Why is it important to prove the shortest distance between two points is a line?
Proving the shortest distance between two points is a line is important because it serves as the basis for many geometric principles and calculations. It allows us to determine the most efficient and direct route between two points, and is a fundamental concept in fields such as physics and engineering.
How do you prove the shortest distance between two points is a line?
The shortest distance between two points is a line can be proven using the Pythagorean theorem and the concept of slope. By finding the distance between the two points using the Pythagorean theorem and then comparing it to the distance along a straight line between the two points, it can be shown that the straight line is the shortest distance.
Are there any exceptions to the shortest distance between two points being a line?
In Euclidean geometry, there are no exceptions to the shortest distance between two points being a line. However, in non-Euclidean geometries, such as spherical or hyperbolic geometry, the shortest distance between two points may not always be a straight line due to the curvature of the space.
What real-life applications does the concept of the shortest distance between two points being a line have?
The concept of the shortest distance between two points being a line has many real-life applications, such as in navigation systems, flight paths, and determining the most efficient routes for transportation. It is also used in engineering and architecture to create the most efficient and stable structures.
  • Mechanics
  • Math POTW for University Students
