Prove the sum of a² and d² is equal the sum of b² and c².
  • MHB
  • Thread starter anemone
  • Tags
    Sum
In summary, the conversation discusses proving the equivalence of $a^2+d^2=b^2+c^2$ given the condition that $a+b\sqrt{2}+c\sqrt{3}+2d\ge \sqrt{10(a^2+b^2+c^2+d^2)}$. The participants provide different solutions, with kaliprasad providing a solution and the other participant acknowledging that their previous solution had a typo. The corrected solution is then explained.
anemone
MHB
POTW Director
3,883
115
Let $a,\,b,\,c,\,d\in \mathbb{R}$ with condition that $a+b\sqrt{2}+c\sqrt{3}+2d\ge \sqrt{10(a^2+b^2+c^2+d^2)}$.
Prove that $a^2+d^2=b^2+c^2$.
Mathematics news on Phys.org
Hint:
Cauchy-Schwarz Inequality
anemone said:
Hint:
by Cauchy-Schawartz in equality we have
$(a^2+b^2+c^2+d^2)(1^2 + \sqrt2^2+ \sqrt3^2+2^2)>=(a+b\sqrt{2}+c\sqrt{3}+2d)^2$
Or $10(a^2 + b^2 + c^2+ d^2)>=(a+b\sqrt{2}+c\sqrt{3}+2d)^2$
Or $\sqrt{10(a^2 + b^2+ c^2+d^2)}>=(a+b\sqrt{2}+c\sqrt{3}+2d)$
from given condition and above we have
$\sqrt{10(a^2 + b^2+c^2+d^2)}=(a+b\sqrt{2}+c\sqrt{3}+2d)^2$
when
$\frac{a}{1}= \frac{b}{\sqrt2}=\frac{c}{\sqrt3}= \frac{d}{2}= k (say)$
So $a = k, b^2= 2k^2,c^2=3k^2,d=2k$ and hence $a^2+d^2=b^2+c^2$
when
Thanks kaliprasad for participating and the nice solution, I solved it a bit different than yours:
By applying the Cauchy Schwarz inequality to the LHS of the given inequality, we get:
$a+b\sqrt{2}+c\sqrt{3}+2d\le \sqrt{10}\sqrt{(a^2+b^2+c^2+d^2)}$
From $\sqrt{10}\sqrt{(a^2+b^2+c^2+d^2)}\le a+b\sqrt{2}+c\sqrt{3}+2d\le \sqrt{10}\sqrt{(a^2+b^2+c^2+d^2)}$, we can conclude that
$a+b\sqrt{2}+c\sqrt{3}+2d=\sqrt{10(a^2+b^2+c^2+d^2)}$.
Using Cauchy Schwarz inequality again, separately, on both $a+2d$ and $b\sqrt{2}+c\sqrt{3}$, we get:
$a+2d≤\sqrt{5(a^2+d^2)}$ and $b\sqrt{2}+c\sqrt{3}\le \sqrt{5(b^2+c^2)}$.
Adding them up and replacing $a+b\sqrt{2}+c\sqrt{3}+2d$ by $\sqrt{10(a^2+b^2+c^2+d^2)}$, we end up getting:
$\sqrt{a^2+d^2}+\sqrt{b^2+c^2}\le 0$, which is true iff $a^2+d^2=b^2+c^2$. (Q. E. D.)
last line is in error as $\sqrt{a^2+d^2}+\sqrt{b^2+c^2}\le 0$ => a=b=c=d = 0 but for other values also it is true
Argh...sorry kaliprasad, last night I wasn't feeling okay and therefore the solution that I posted (with typo) in a hurry didn't quite hold water.
I therefore want to give the reasoning that I've "in my mind" that would definitely work, to amend the incomplete solution I posted yesterday:
$\sqrt{10(a^2+b^2+c^2+d^2)}\le \sqrt{5(a^2+d^2)}+\sqrt{5(b^2+c^2)}$
$\sqrt{2(a^2+b^2+c^2+d^2)}\le \sqrt{a^2+d^2}+\sqrt{b^2+c^2}$
Squaring both sides gives
$2(a^2+b^2+c^2+d^2)\le a^2+d^2+2\sqrt{a^2+d^2}\sqrt{b^2+c^2}+b^2+c^2$
$a^2+d^2-2\sqrt{a^2+d^2}\sqrt{b^2+c^2}+b^2+c^2\le 0$
$(\sqrt{a^2+d^2}-\sqrt{b^2+c^2})^2\le 0$, which is true iff $a^2+d^2=b^2+c^2$. (Q. E. D.)
FAQ: Prove the sum of a² and d² is equal the sum of b² and c².
What is the formula for proving the sum of a² and d² is equal to the sum of b² and c²?
The formula for proving this statement is (a² + d²) = (b² + c²).
How can I prove this statement using algebraic manipulation?
You can prove this statement by expanding both sides of the equation using the FOIL method and then simplifying the resulting expressions.
Can this statement be proved using a geometric proof?
Yes, this statement can also be proved using a geometric proof by constructing squares on each side of the equation and showing that they have equal areas.
What are the implications of this statement in geometry?
This statement is known as the Pythagorean theorem and has many implications in geometry, including its use in calculating the length of the hypotenuse in a right triangle.
Is this statement applicable to all numbers, or are there any restrictions?
This statement is applicable to all real numbers, as long as they are positive. It is also applicable to complex numbers, as long as they can be squared and added together.
