MHB Prove the trig inequality ∑α∈{A,B,C}1/[1+sin(α/2)]≥2
  • Thread starter Thread starter lfdahl
    Inequality Trig
The discussion focuses on proving the inequality for any triangle, specifically that the sum of the reciprocals of \(1 + \sin(\alpha/2)\) for angles A, B, and C is greater than or equal to 2. Participants express appreciation for each other's solutions, particularly highlighting contributions from MarkFL. There is a request for alternative solutions that do not rely on cyclic symmetry. Additional approaches to the problem are also mentioned, indicating a collaborative effort to explore various methods of proof. The conversation emphasizes the mathematical challenge and the community's engagement in finding solutions.
lfdahl
MHB
Prove, that for any triangle:
\[\sum_{\alpha \in \left \{ A,B,C \right \}}\frac{1}{1+\sin \frac{\alpha }{2}}\geq 2\]
Mathematics news on Phys.org
My solution:
We have the objective function:
$$f(A.B,C)=\frac{1}{1+\sin\left(\dfrac{A}{2}\right)}+\frac{1}{1+\sin\left(\dfrac{B}{2}\right)}+\frac{1}{1+\sin\left(\dfrac{C}{2}\right)}$$
Subject to the constraint:
$$g(A,B,C)=A+B+C-\pi=0$$
We see by cyclic symmetry that the critical value occurs at:
$$A=B=C=\frac{\pi}{3}$$
And we find:
$$f\left(\frac{\pi}{3},\frac{\pi}{3},\frac{\pi}{3}\right)=\frac{3}{1+\sin\left(\dfrac{\pi}{6}\right)}=2$$
Using another point on the constraint, we find:
$$f\left(\frac{\pi}{6},\frac{\pi}{3},\frac{\pi}{2}\right)\approx2.04684845753400>2$$
Thus, we may assert:
$$f_{\min}=2$$
Shown as desired. :D
Well done, MarkFL! Thankyou for your participation!
Your response came before my ink dried ;)
May I also ask the forum participants for a solution without the use of cyclic symmetry? :o
Here's another solution:
Using the AM-GM inequality, we may state:
$$\frac{1}{3}\sum_{k=1}^3\left(\frac{1}{1+\sin\left(\dfrac{\theta_k}{2}\right)}\right)\ge\sqrt[3]{\prod_{k=1}^3\left(\frac{1}{1+\sin\left(\dfrac{\theta_k}{2}\right)}\right)}$$
We have that equality occurs for:
$$\theta_1=\theta_2=\theta_3=\frac{\pi}{3}$$
Hence:
$$\frac{1}{3}\sum_{k=1}^3\left(\frac{1}{1+\sin\left(\dfrac{\theta_k}{2}\right)}\right)\ge\frac{2}{3}$$
Or:
$$\sum_{k=1}^3\left(\frac{1}{1+\sin\left(\dfrac{\theta_k}{2}\right)}\right)\ge2$$
Thanks a lot, MarkFL, for a very fine solution!A third approach can be found here:
Note, that the function $\frac{1}{1+\sin x}$ is convex on $[0;\frac{\pi}{2}]$, and that the angles: $\frac{A}{2}$, $\frac{B}{2}$, $\frac{C}{2}$ all belong to the same interval.
Using Jensen´s inequality:
\[\frac{1}{1+\sin \frac{A}{2}}+\frac{1}{1+\sin \frac{B}{2}}+\frac{1}{1+\sin \frac{C}{2}} \geq \frac{3}{1+\sin \left (\frac{\frac{A}{2}+\frac{B}{2}+\frac{C}{2}}{3} \right ) }= \frac{3}{1+\sin 30^{\circ}}=2\]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
