Prove the wave function for dxy orbital
In summary, the conversation discusses the angular part of the wave function for the dxy orbital and its corresponding expression. The conversion of Cartesian to spherical coordinates is used to show that the expression is equivalent to the dxy orbital. The conversation also mentions the normalization of the equation, but this is not necessary to show its correspondence to the dxy orbital. The total wave function for the dxy orbital is of the form ##\psi(\vec{r}) = R_{nl}(r)Y_l^m(\theta,\phi)## and the normalization condition is given by $$\int \psi^*(\vec{r})\psi(\vec{r})\,d^3\vec{r} = \int R^
chem1309
"The angular part of the wave function for the dxy orbital is (√(15/∏)/4)sin^2(θ)sin(2[itex]\phi[/itex]). Show that this expression corresponds to the dxy orbital"
conversion of Cartesian to spherical coordinates:
r=√(x^2+y^2+z^2)
cosθ=z/r
tan([itex]\phi[/itex])=y/x
trig identity:
sin(2x)=2sinxcosx
normalization:
N^2∫ψ*ψdτ
dτ=r^2sinθdrdθd[itex]\phi[/itex]
0≤r≤∞
0≤θ≤∏
0≤[itex]\phi[/itex]≤2∏
in Cartesian coordinates dxy is represented as simply xy. I converted xy to spherical coordinates and manipulated the equation the relevant equations to get xy=(r/2)sin^2(θ)sin(2[itex]\phi[/itex]) as follows:
xy=rsincos[itex]\phi[/itex]rsinθsin[itex]\phi[/itex]
xy=rsin^2(θ)cos[itex]\phi[/itex]sin[itex]\phi[/itex]
xy=rsin^2(θ)sin(2[itex]\phi[/itex])/2
Then I tried to normalize the equation, but I ended up with
∫r^3 from 0 to ∞, which goes to ∞/does not converge
and ∫sin2[itex]\phi[/itex] which equal zero.
I'm not sure why you think you need to normalize the wave function to show it corresponds to the dxy orbital.
In any case, the total wave function is of the form ##\psi(\vec{r}) = R_{nl}(r)Y_l^m(\theta,\phi)##. Normalization requires that
$$\int \psi^*(\vec{r})\psi(\vec{r})\,d^3\vec{r} = \int R^*_{nl}(r)R_{nl}(r)\,dr \int {Y_l^m}^*(\theta,\phi)Y_l^m(\theta,\phi)\,d\Omega = 1.$$ Does seeing this clear up your two questions?
FAQ: Prove the wave function for dxy orbital
What is the wave function for the dxy orbital?
The wave function for the dxy orbital is given by Ψ = Axy(x,y,z)e^(-r/ao), where Axy is a normalization constant, x, y, and z are the Cartesian coordinates, and ao is the Bohr radius.
How is the wave function for the dxy orbital derived?
The wave function for the dxy orbital is derived by solving the Schrödinger equation for a hydrogen atom with the appropriate quantum numbers (n=2, l=2, m=±2). This results in a solution that is a combination of radial and angular components, with the angular component being Axy(x,y,z).
What does the wave function for the dxy orbital represent?
The wave function for the dxy orbital represents the probability amplitude of finding an electron in a specific location within the dxy orbital. It is a mathematical function that describes the behavior and properties of the electron in this orbital.
How does the shape of the dxy orbital relate to its wave function?
The shape of the dxy orbital is directly related to its wave function, as the squared magnitude of the wave function gives the probability density of finding an electron at a specific point in space. Therefore, the shape of the dxy orbital can be visualized by plotting the probability density at different points in space.
Does the wave function for the dxy orbital change with the presence of other atoms or molecules?
Yes, the wave function for the dxy orbital can change in the presence of other atoms or molecules due to the influence of their electric fields. This can result in the distortion or hybridization of the dxy orbital, altering its shape and properties.
