Prove there are infinitely many primes using Mersenne Primes
In summary, the attempt to prove the existence of infinitely many primes using Mersenne Primes relies on the assumption that if k is prime, then 2^k - 1 is prime. However, this assumption is false and therefore it cannot be proven that there are infinitely many primes using Mersenne Primes.
Kitty Kat
Prove that there are infinitely many primes using Mersenne Primes, or show that it cannot be proven with Mersenne Primes.
A Mersenne prime has the form: M = 2k - 1
Lemma: If k is a prime, then M = 2k - 1 is a prime.
Proof of Lemma: Assume that k is composite, then 2k - 1 must also be composite.
k = a * b
2ab - 1 is then divisible by both (2a - 1) and (2b - 1)
Therefore k must be a prime.
Proof for problem
Assume there are finitely many primes, p1, ... , pr, and let pr be the last prime.
Then by Lemma 1, 2pr - 1 is a Mersenne prime, which is certainly larger than pr, therefore there are infinitely many primes.
After writing all this out, I realized that the lemma is most certainly false, so I guess there isn't a way to prove infinitely many primes with Mersenne Primes, since the number of Mersenne Primes themselves are an open question.
You appear to think you have proved that if ##k## is prime, then ##2^k -1## is prime. This is false. E.g ##k = 11##
You have proved the converse: If ##2^k -1## is prime, then ##k## is prime.
Likes Kitty Kat
Related to Prove there are infinitely many primes using Mersenne Primes
1. What are Mersenne Primes?
Mersenne primes are prime numbers that can be represented in the form of 2^n - 1, where n is also a prime number. They are named after the French mathematician Marin Mersenne who studied them in the 17th century.
2. How do Mersenne Primes relate to proving the infinitude of primes?
The relationship between Mersenne Primes and proving the infinitude of primes lies in the fact that any prime number can be expressed in the form of a Mersenne Prime. Therefore, by showing that there are infinitely many Mersenne Primes, we can also prove that there are infinitely many prime numbers.
3. Why is proving the infinitude of primes important?
Proving the infinitude of primes is important because it is a fundamental concept in mathematics. It helps us understand the distribution of prime numbers and their role in number theory. It also has practical applications in cryptography and computer science.
4. How does the proof using Mersenne Primes work?
The proof using Mersenne Primes works by assuming that there is a largest prime number, denoted by P. Then, by using the formula 2^P - 1, we can generate a new number that is either prime or has a prime factor larger than P. This contradicts our initial assumption that P is the largest prime, thus proving that there are infinitely many primes.
5. Are there any other proofs for the infinitude of primes?
Yes, there are multiple proofs for the infinitude of primes, including Euclid's proof, Euler's proof, and the proof using the prime number theorem. Each of these proofs uses different mathematical concepts and techniques, but they all ultimately show that there are infinitely many prime numbers.
