MHB Prove Triangle Inequality: AB/MZ + AC/ME + BC/MD ≥ 2t/r
  • Thread starter Thread starter solakis1
    Geometrical
The discussion focuses on proving the inequality involving a triangle ABC and a point M inside it, where perpendiculars MZ, MD, and ME are drawn to the sides AB, BC, and AC, respectively. The goal is to demonstrate that the sum of the ratios of the triangle's sides to these perpendiculars is greater than or equal to twice the semi-perimeter divided by the inradius. The Cauchy-Schwarz inequality is suggested as a useful tool for the proof. Participants explore various approaches and mathematical principles to establish the validity of the inequality. The proof highlights the relationship between triangle geometry and inequalities, emphasizing the significance of the inscribed circle's radius.
solakis1
Given a triangle ABC and a point M inside the triangle ,draw perpendiculars MZ,MD,ME at the sides AB,BC,AC respectively. Then prove:$$\frac{AB}{MZ}+\frac{AC}{ME}+\frac{BC}{MD}\geq\frac{2t}{r}$$
Where t is half the perimeter of the triangle and r is the radius of the inscribed circle
Mathematics news on Phys.org
[sp]Here also the Cauchy-Schwarz inequality may be used for the solution of the problem[/sp]
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
