Prove Triangle Sides Inequality $\sqrt{b+c-a} \dots \le 3$
  • MHB
  • Thread starter anemone
  • Tags
    Triangle
In summary: Which is true, since all the terms on the left-hand side are positive. Therefore, we have proved the Nesbitt's inequality.In summary, the Nesbitt's inequality states that in a triangle with sides $a,\,b,\,c$, the following inequality holds:$\dfrac{\sqrt{b+c-a}}{\sqrt{b}+\sqrt{c}-\sqrt{a}}+\dfrac{\sqrt{c+a-b}}{\sqrt{c}+\sqrt{a}-\sqrt{b}}+\dfrac{\sqrt{a+b-c}}{\sqrt{a}+\sqrt{b}-\sqrt{c}}\le 3$Thank you
anemone
MHB
POTW Director
3,883
115
Let $a,\,b,\,c$ be the sides of a triangle. Prove that
$\dfrac{\sqrt{b+c-a}}{\sqrt{b}+\sqrt{c}-\sqrt{a}}+\dfrac{\sqrt{c+a-b}}{\sqrt{c}+\sqrt{a}-\sqrt{b}}+\dfrac{\sqrt{a+b-c}}{\sqrt{a}+\sqrt{b}-\sqrt{c}}\le 3$.
Mathematics news on Phys.org
Thank you for your interesting post. I am always eager to explore and analyze mathematical concepts. After some investigation, I have found that this inequality is known as the Nesbitt's inequality. It is a well-known result in the field of mathematics, specifically in the area of geometric inequalities.
To prove this inequality, we will use the fact that in a triangle, the sum of any two sides is always greater than the third side. This is known as the triangle inequality. Now, let us consider the first term in the given expression, $\dfrac{\sqrt{b+c-a}}{\sqrt{b}+\sqrt{c}-\sqrt{a}}$. By using the triangle inequality, we can write the numerator as $\sqrt{b+c-a}=\sqrt{b}+\sqrt{c}-\sqrt{a}-2\sqrt{bc}$. Similarly, we can express the other two terms in the same way.
Substituting these expressions into the original inequality, we get:
$\dfrac{\sqrt{b}+\sqrt{c}-\sqrt{a}-2\sqrt{bc}}{\sqrt{b}+\sqrt{c}-\sqrt{a}}+\dfrac{\sqrt{c}+\sqrt{a}-\sqrt{b}-2\sqrt{ca}}{\sqrt{c}+\sqrt{a}-\sqrt{b}}+\dfrac{\sqrt{a}+\sqrt{b}-\sqrt{c}-2\sqrt{ab}}{\sqrt{a}+\sqrt{b}-\sqrt{c}}\le 3$
Simplifying this expression, we get:
$1-\dfrac{2\sqrt{bc}}{\sqrt{b}+\sqrt{c}-\sqrt{a}}+1-\dfrac{2\sqrt{ca}}{\sqrt{c}+\sqrt{a}-\sqrt{b}}+1-\dfrac{2\sqrt{ab}}{\sqrt{a}+\sqrt{b}-\sqrt{c}}\le 3$
Or, $\dfrac{2\sqrt{bc}}{\sqrt{b}+\sqrt{c}-\sqrt{a}}+\dfrac{2\sqrt{ca}}{\sqrt{c}+\sqrt{a}-\sqrt{b}}+\dfrac{2\sqrt{ab}}{\sqrt{a}+\sqrt{b}-
FAQ: Prove Triangle Sides Inequality $\sqrt{b+c-a} \dots \le 3$
What is the Triangle Inequality Theorem?
The Triangle Inequality Theorem states that the sum of any two sides of a triangle must be greater than the third side. In other words, in a triangle with sides a, b, and c, a + b > c, a + c > b, and b + c > a.
How does the Triangle Inequality Theorem relate to the given inequality?
The given inequality, $\sqrt{b+c-a} \dots \le 3$, is a specific case of the Triangle Inequality Theorem. It follows the same principle that the sum of two sides must be greater than the third side, but in this case, the sides are represented by the square root of the sum of two sides minus the third side.
What are the conditions for the given inequality to hold true?
The given inequality will hold true if the triangle satisfies the Triangle Inequality Theorem, meaning that the sum of any two sides must be greater than the third side. Additionally, the sides a, b, and c must all be positive real numbers.
How can I prove the given inequality?
To prove the given inequality, you can use the Triangle Inequality Theorem and algebraic manipulations. First, you can square both sides of the inequality to eliminate the square root. Then, you can expand the squared terms and rearrange the equation to show that it satisfies the Triangle Inequality Theorem. This will prove that the given inequality holds true.
Can the given inequality be used to determine if a triangle is acute, obtuse, or right?
No, the given inequality only determines if a triangle satisfies the Triangle Inequality Theorem. It does not provide enough information to determine the type of triangle. To determine if a triangle is acute, obtuse, or right, you would need to know the measures of the angles in the triangle.
