MHB Prove trig identity (cot x -1)/(cot x +1)=(1-sin 2x)/(cos 2x)
  • Thread starter Thread starter karush
    Identity Trig
The discussion focuses on proving the trigonometric identity (cot x - 1)/(cot x + 1) = (1 - sin 2x)/(cos 2x). Participants work through the algebraic manipulation of the left side, simplifying it to match the right side. A correction is noted regarding the numerator, which should include sin^2(x) instead of just cos^2(x). After adjustments, the identity is confirmed as valid. The final expression shows both sides of the equation are equal, successfully proving the identity.
karush
MHB
$\begin{align*}
\frac{\cot {x}-1}{\cot{x}+1}&=\frac{1-\sin 2x}{\cos 2x}\\
\frac{\cos {x}-\sin x}{\cos{x}+\sin x}
\frac{\cos x-\sin x}{\cos x-\sin x}&= \\
\frac{\cos^2x-2\sin x\cos x+\cos^2 x}{\cos^2 x-\sin^2 x}
\end{align*}$
so far..
Mathematics news on Phys.org
karush said:
$\begin{align*}
\end{align*}$
so far..
Check your numerator. It should be [math]cos^2(x) - 2~sin(x)~cos(x) + sin^2(x)[/math].
Otherwise it's good. :)
-Dan
$\begin{align*}
\frac{\cos^2x-2\sin x\cos x+\sin^2 x}
{\displaystyle cos^2x- sin^2x}=\\
\end{align*}$
hopefully
Yup, you got it. (Yes)
-Dan
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
