Prove TV(f) ≤ lim inf TV(fn): Total Variation Homework
  • Thread starter sbashrawi
  • Tags
    Variation
In summary: Therefore, TV(f) ≤ lim inf TV(fn).In summary, we can show that TV(f) ≤ lim inf TV(fn) by using the fact that the sequence of functions {fn} converges pointwise to f, and by using the definitions of pointwise convergence and total variation. By making use of the triangle inequality, we can show that the difference between TV(fn) and TV(f) approaches zero as n goes to infinity, and therefore TV(f) ≤ lim inf TV(fn).
sbashrawi
55
Let {fn} be a sequence of real-valued functions on [a, b] that
converges pointwise on [a, b] to the real-valued function f. Show that
TV (f) <= lim inf TV (fn).
I prove it in the follwoing way:
|fn(xi) - f(xi) | = 0 as n goes to infinity, then
| sum ( fn(xi) - f(xi)| goes to zero
| sum [ fn(xi) - fn(x_i-1)] - sun [ f(xi) - f(x_i-1)]| goes to zero
so the total variation TV(fn) converges to TV(f) point wise
hence TV(f) <= lim inf TV(fn)
but I am not sure about it since there is no condition that gurantees the concolusion
that the difference of TV is zero as n goes to infinity.
Thank you for your post. Your solution is on the right track, but there are a few details that need to be clarified.
Firstly, the statement "TV(fn) converges to TV(f) pointwise" is not entirely accurate. The total variation of a function is a real number, not a function, so it cannot converge pointwise. What you mean to say is that the sequence of total variations {TV(fn)} converges to TV(f), which is a real number.
Secondly, your argument about the difference of TV being zero as n goes to infinity is not completely justified. While it is true that the difference of TV(fn) and TV(f) will approach zero as n goes to infinity, this does not necessarily mean that the difference itself will be zero. In order to prove this, you need to use the fact that the sequence of functions {fn} converges pointwise to f. This means that for any given x in [a,b], the values of fn(x) will get closer and closer to f(x) as n goes to infinity. Therefore, the difference between fn(xi) and f(xi) will approach zero as n goes to infinity, and this will hold for all xi in [a,b].
To make this argument more rigorous, you can use the definition of pointwise convergence and the triangle inequality to show that for any given ε > 0, there exists an N ∈ ℕ such that for all n ≥ N and all x ∈ [a,b], |fn(x) - f(x)| < ε. From here, you can use the fact that TV is a non-negative function and apply the triangle inequality again to get |TV(fn) - TV(f)| ≤ TV(|fn - f|) < ε(b-a). This shows that the difference between TV(fn) and TV(f) can be made arbitrarily small, and therefore it must be equal to zero.
Once you have established that the difference between TV(fn) and TV(f) is zero, you can conclude that TV(f) ≤ lim inf TV(fn) as you did in your solution. This is because for any given ε > 0, there exists an N ∈ ℕ such that for all n ≥ N, TV(fn) < TV(f) + ε. Taking the limit as n goes to infinity, you get lim inf TV(fn) ≤ TV(f) + ε
FAQ: Prove TV(f) ≤ lim inf TV(fn): Total Variation Homework
What is "Prove TV(f) ≤ lim inf TV(fn): Total Variation Homework"?
"Prove TV(f) ≤ lim inf TV(fn): Total Variation Homework" is a mathematical statement that involves the total variation (TV) of a function (f) and the limit inferior of the total variation of a sequence of functions (fn). It is a common question in advanced math courses and is used to evaluate the convergence of a sequence of functions.
What is total variation?
Total variation is a measure of the overall variability or change in a function. It is calculated by taking the integral of the absolute value of the function's derivative. In other words, it measures how much a function deviates from being constant.
How is the total variation of a function related to its convergence?
The total variation of a function is closely related to its convergence. If the total variation of a function is finite, then the function is said to be of bounded variation and it is known to have good convergence properties. This is why the total variation is often used as a tool to prove the convergence of a sequence of functions.
What does "lim inf" mean in the statement "lim inf TV(fn)"?
"Lim inf" stands for limit inferior, which is a mathematical concept used to describe the smallest accumulation point of a sequence. In the statement "lim inf TV(fn)", it represents the smallest possible value that the total variation of the sequence of functions (fn) can approach.
How do you prove "Prove TV(f) ≤ lim inf TV(fn): Total Variation Homework"?
Proving "Prove TV(f) ≤ lim inf TV(fn): Total Variation Homework" requires a strong understanding of mathematical analysis and convergence. One approach is to use the definition of total variation and the properties of limit inferior to show that the total variation of the function (f) is always less than or equal to the limit inferior of the total variation of the sequence of functions (fn).
