Prove u(A/E)=0 for Compact Hausdorff Spaces and Borel Measure
In summary: Therefore $\mu(A\cap E) = \mu(A) + \mu(E^c)$ for all $c\in\mathbb{C}$. This implies that $\mu(A)=\mu(A\cap E)$
Fermat1
187
Let K be a compact hausdorff space, and u a borel measure on K. You are given that if A is an open set in K with A and E disjoint, we have u(A)=0. (E is a certain closed set in K)
Show that for a borel set A, we have that u(AE)=u(A), where AE is the intersection.
we have that u(A)=u(AE)+u(A\E) so we only have to prove u(A/E)=0
u(A/E)=inf(u(M):M is open and A\E is a subset of M)
A\E is disjoint with E but unfortunately this does not imply M is disjoint with E .
This argument seems too simple to be believable, but I can't see what's wrong with it (I'm suspicious, because it does not use the compactness of $K$). You are given that $E$ is closed, so its complement $K\setminus E$ is an open set disjoint from $E$. Therefore $u(K\setminus E) = 0.$ If $A$ is a Borel set then $u(A\setminus E) \leqslant u(K\setminus E) = 0$.
Is the last part simply because A\E is a subset of K\E?
Yes. If $X$, $Y$ are Borel sets with $X\subseteq Y$ then $u(X)\leqslant u(Y)$.
Indeed, in the use of outer regularity, there is a problem as the involved $M$ may not be disjoint with $E$.
We have to show that the measures $\mu$ and $\nu\colon A\mapsto \mu(A\cap E)$ are actually equal.
Since the ambient space is compact, we can assume that $\mu$ is finite. We only have to check that the relationship $\mu(A)=\mu(A\cap E)$ holds for $A$ an open set. Using closeness of $E$, $A\cap E^c$ is an open set disjoint with $E$.
FAQ: Prove u(A/E)=0 for Compact Hausdorff Spaces and Borel Measure
What is the definition of u(A/E)?
u(A/E) is the outer measure of the set A with respect to the set E. It is defined as the infimum of the measures of all coverings of A by countable number of sets that are contained in E.
What is a Compact Hausdorff Space?
A Compact Hausdorff Space is a topological space that is both compact and Hausdorff. Compactness means that every open cover of the space has a finite subcover, while Hausdorffness means that every two distinct points in the space have disjoint neighborhoods.
What is Borel Measure?
Borel Measure is a type of measure used in mathematics to assign a numerical value to certain subsets of a topological space. It is commonly used in integration theory and probability theory.
Why is the proof of u(A/E)=0 important for Compact Hausdorff Spaces?
The proof of u(A/E)=0 for Compact Hausdorff Spaces is important because it shows that under certain conditions, the outer measure of a set with respect to another set is equal to 0. This has implications in measure theory and helps to understand the properties of compact spaces.
What are the practical applications of this proof?
The proof of u(A/E)=0 for Compact Hausdorff Spaces has practical applications in fields such as analysis, probability theory, and topology. It helps to understand the properties of compact spaces and can be used in various mathematical and scientific calculations and proofs.
