Prove what the exterior derivative of a 3-form is....
In summary: That is painful because the Leibniz rule for the first two terms in ##3dσ(X,Y,Z)## gives ##3dσ(X,Y,Z) = -X.Y.σ(Z) + Y.σ(X,Z) - Z.σ(X,Y) + σ([X,Y],Z) - σ([X,Z],Y) + σ([Y,Z],X)##. The first three terms cancel and the second three terms cancel if we use the identity ##[X,Y].Z = X.[Y,Z] - Y.[X,Z]##. In other words the Leibniz rule for the first two terms can be written##3X.σ(Y,Z) = X.σ(Y,Z
Fgard
I am trying to prove the following:
$$3d\sigma (X,Y,Z)=-\sigma ([X,Y],Z)$$
where ##X,Y,Z\in\mathscr{X}(M)## with M as a smooth manifold. I can start by stating what I know so it is easier to see what I do wrong for you guys.
I know that a general 2-form has the form:
##\omega=\omega_{ij}dx^i\land dy^j##. if one "puts" in two vector fields, ##X=X^{\mu}\frac{\partial}{\partial X^{\mu}}## and ##Y=Y^{\nu}\frac{\partial}{\partial X^{\nu}}## one gets
$$\omega(X,Y)=\omega_{\alpha\beta} Y^{\nu}\frac{\partial}{\partial X^{\nu}}X^{\mu}\frac{\partial}{\partial X^{\mu}}dx^{\alpha}\land dy^{\beta} =\omega_{\alpha\beta} (Y^{\beta}X^{\alpha}-Y^{\alpha}X^{\beta})$$
One of my problems is that I don't know how to treat the lie bracket inside the 2-form. Specifically the corresponding wedge that it should yield. This is what my efforts have gotten me so far:
$$-\sigma ([X,Y],Z)=-\sigma_{\alpha\beta}(X^{\nu}Y^{\mu}\frac{\partial^2}{\partial X^{\nu}X^{\mu}}-Y^{\mu}X^{\nu}\frac{\partial^2}{\partial X^{\nu}X^{\mu}})d(XY)^{\alpha} \land dz^{\beta} $$
This doesn't get me anywhere, so my conclusion is that I am messing it up some where. (I know by the way that there is a formula that you can use, but I want to understand what it does that is why I am trying this. )
A Lie bracket does not yield a wedge. It yields a vector field. Thus we have
$$[X,Y]\equiv \left(X^j\partial_jY^k-Y^j\partial_jX^k\right)\partial _k$$
So if [itex]\sigma[/itex] is a 2-form and we write [itex]T\equiv[X,Y][/itex], we have
$$-\sigma([X,Y],Z)=-\sigma(T,Z)=-\sigma_{ab}dx^a\wedge dx^b(T,Z)=-\sigma_{ab} (Z^{\beta}T^a-Z^{\alpha}T^b)$$
$$\ \ \ \ \ \ \ \ \ \ =-\sigma_{ab} \left(Z^{b}\left(X^j\partial_jY^a-Y^j\partial_jX^a\right)-Z^{a}\left(X^j\partial_jY^b-Y^j\partial_jX^b\right)\right)$$
By the way, I recommend against writing basis vectors as ##\frac{\partial}{\partial X^\mu}## because the capital ##X## is used to denote a specific vector and the basis vector has nothing to do with that vector. I like to use ##\partial_\mu## because it's clear, quick to write and say but another option is ##\frac{\partial}{\partial x^\mu}## (note the lower case ##x##).
Thanks for your help andrewkirk, it cleared up my confusion with the Lie bracket. I see now that i forgot to mention in my initial post that:
$$X,Y\in V_K(M)$$ and $$Z\in V(M)$$
With K as the characteristic distribution of ##\sigma## and X,Y are tangent to this distribution.
There is an alternative definition of the exterior derivative that you might find easier to work with.
For functions ##df(X) = X.f##
For 1 forms ##2dσ(X,Y) = X.σ(Y)-Y.σ(X) -σ([X,Y])##
For two forms ##3dσ(X,Y,Z) = X.σ(Y,Z) - Y.σ(X,Z) + Z.σ(X,Y) - σ([X,Y],Z) + σ([X,Z],Y) - σ([Y,Z],X) ##
The formula generalizes to n-forms.
Likes zinq
To get a feel for this definition of exterior derivative, and how the Lie bracket works in it, here are some computations for 1 forms.
First, if ##σ = df## for some function ##f## then ##2dσ(X,Y)## becomes ##X.Y.f-Y.X.f -[X,Y].f## This is zero by definition of the Lie bracket. So ##d^2f = 0 ## as required.
Next notice that as a function of ##X## and ##Y##, ##X.σ(Y)-Y.σ(X)## without the Lie bracket term is not a 2 form. It is anti-commutative and linear over constants but if one multiplies ##X## by a function ##f##, one gets
##fXσ(Y) - Y.σ(fX) = fX.σ(Y) - (Y.f)σ(X) -fY.σ(X)## by the Leibniz rule. So this expression depends on the derivative of ##f##.
The third term in the definition of ##dσ## fixes this. The identity ##[fX,Y] = -(Y.f)X + f[X,Y]## gives
##σ([fX,Y]) = -(Y.f)σ(X) + fσ([X,Y])## so subtracting this cancels the problematic term in ##Y.f## and what is left is
##fXσ(Y) -fY.σ(X) - fσ([X,Y]) = fdσ(X,Y)##
If you have the patience, check that ##d^2 = 0## on 1 forms.
Related to Prove what the exterior derivative of a 3-form is....
1. What is the exterior derivative of a 3-form?
The exterior derivative of a 3-form is a mathematical operation that takes a 3-form as input and produces a 4-form as output. It is a generalization of the concept of the derivative from single-variable calculus to higher dimensions.
2. How is the exterior derivative of a 3-form different from the derivative of a function?
The exterior derivative of a 3-form is different from the derivative of a function in several ways. Firstly, while the derivative of a function is a scalar or a vector, the exterior derivative of a 3-form is a 4-form. Additionally, the exterior derivative of a 3-form is defined on differential forms, which are objects that generalize both functions and vectors in higher dimensions.
3. What is the purpose of calculating the exterior derivative of a 3-form?
The exterior derivative of a 3-form is useful in many areas of mathematics and physics, including differential geometry, differential topology, and gauge theory. It allows us to study how a 3-form changes locally and globally, and to understand the structure of manifolds and other geometric objects.
4. Can you explain the formula for calculating the exterior derivative of a 3-form?
The formula for calculating the exterior derivative of a 3-form involves using the exterior product (also known as the wedge product) to combine the 3-form with the basis forms of the underlying space. This results in a new 4-form that represents the change of the original 3-form in each direction. The formula can also be expressed in terms of the exterior derivative operator, which acts on the coefficients of the 3-form to produce the coefficients of the 4-form.
5. Are there any applications of the exterior derivative of a 3-form in real-world problems?
Yes, the exterior derivative of a 3-form has many applications in real-world problems, particularly in physics and engineering. It is used in the study of fluid dynamics, electromagnetism, and general relativity, among others. In these fields, the exterior derivative of a 3-form helps to describe the behavior of physical quantities such as electric and magnetic fields, and fluid flow.
  • Differential Geometry
