Prove x^31+x^32+x^33+x^34+x^35=n has an integer solution for any integer n.
  • MHB
  • Thread starter lfdahl
  • Tags
    Integer
In summary, to prove the equation x^31+x^32+x^33+x^34+x^35=n has an integer solution for any integer n, we can use mathematical induction. There is no specific method or formula for finding the integer solution for this equation, but the use of mathematical induction is a commonly used approach. One example of an integer solution is x=0. This equation can have multiple integer solutions, and cannot be solved for non-integer values of n.
lfdahl
MHB
749
Prove, that the equation
has an integer solution for any integer .
Mathematics news on Phys.org
We have
or
let us define which is sum of of 4 cubes
the numbers are of the form
sum of 5 cubes
sum of 5 cubes
sum of 5 cubes
sum of 5 cubes
sum of 5 cubes
sum of 5 cubes
as we have taken care of all cases we are done
kaliprasad said:
We have
or
sum of 5 cubes
sum of 5 cubes
sum of 5 cubes
sum of 5 cubes
sum of 5 cubes
sum of 5 cubes
You really cracked the nut with a splendid solution, kaliprasad! :cool:Thanks a lot for your participation!
kaliprasad said:
We have
or
sum of 5 cubes
sum of 5 cubes
sum of 5 cubes
sum of 5 cubes
sum of 5 cubes
sum of 5 cubes
better solution that is closed form ( first 3 lines copied from above)
We have
or
now Now is integer as being multiple of 3 consecutive numbers is divisible by 3! or 6
so sum of one cube and 4 cubes or sum of 5 cubes
We have
or
Thanks again, kaliprasad!Yes, the latter solution is more compact in its closed form. Nice observation!
FAQ: Prove x^31+x^32+x^33+x^34+x^35=n has an integer solution for any integer n.
How do you prove that x^31+x^32+x^33+x^34+x^35=n has an integer solution for any integer n?
To prove this equation, we can use mathematical induction. We first show that the equation holds true for n=1. Then, we assume that the equation holds true for some integer k, and use this assumption to show that it also holds true for k+1. This establishes the equation as true for all positive integers, and therefore for all integers.
Is there a specific method or formula for finding the integer solution for this equation?
No, there is no specific method or formula for finding the integer solution for this equation. However, the use of mathematical induction as mentioned in the previous answer is a commonly used approach for proving equations like this one.
Can you give an example of an integer solution for this equation?
Yes, one possible integer solution for this equation is x=0. Plugging in x=0, we get 0^31+0^32+0^33+0^34+0^35=0 which satisfies the equation for any integer n.
Is it possible for this equation to have multiple integer solutions?
Yes, it is possible for this equation to have multiple integer solutions. As mentioned in the previous answer, x=0 is one possible solution, but there may be other integer values of x that also satisfy the equation for different values of n.
Can this equation be solved for non-integer values of n?
No, this equation can only be solved for integer values of n. The variable n represents any integer in the equation, so plugging in non-integer values for n would not result in a meaningful solution.
