Provincial Exam: Simple momentum explosion question
In summary, a 1.0kg physics puck is broken into three pieces by a small explosion. The first piece, weighing 0.50 kg, travels north at 10 m/s and the second piece, weighing 0.3 kg, goes east at 20 m/s. Using the equations p = mv and Momentum Before = Momentum After, it can be determined that the momentum before the explosion was zero and the sum of the momentum on the x-axis and y-axis is also zero. To maintain the law of momentum conservation, the momentum of the third piece should be equal and opposite to the net momentum of the first two pieces. However, calculations using the Pythagorean theorem result in a momentum of 7.8
Senjai
104
A 1.0kg physics puck is at rest when a small explosion breaks it into three pieces. A 0.50 kg piece, goes north at 10 m/s, a .3 kg piece goes east at 20 m/s. What is the magnitude of the momentum of the third piece.
[tex]p = mv[/tex]
So i know that the momentum before is zero, so the sum of the momentum on the x-axis is zero, and the sum on the y-axis is zero.
Because the first two pieces are at right angles to each other, i calculated the net momentum, or their resultant, and stated that the momentum of the third piece should be equal and opposite to maintain the law of momentum conservation.
So i determined: the first piece had a momentum of 5 kg m/s north, the second, 6 kg m/s east.
Plugged the values into the pythagorean theorum and got 7.8 kg m/s..
Which is an answer on the sheet, but it's wrong. The correct answer is 3.3 kg m/s
Could anyone tell me where i went wrong??
Regards,
Senjai
*bump* :(
I would like to commend you for your attempt at solving this problem. However, your approach may have been incorrect.
Firstly, you mentioned that the momentum before the explosion is zero, which is correct. However, you cannot simply add the momenta of the two pieces to determine the momentum of the third piece. This is because momentum is a vector quantity and it has both magnitude and direction.
To solve this problem, we can use the law of conservation of momentum, which states that the total momentum of a system remains constant before and after an event. In this case, the event is the explosion.
So, the momentum before the explosion is equal to the momentum after the explosion. We can write this mathematically as:
m1v1 + m2v2 = m3v3
Where m1, v1 are the mass and velocity of the first piece, m2, v2 are the mass and velocity of the second piece, and m3, v3 are the mass and velocity of the third piece.
We know the values of m1, m2, v1 and v2 from the problem statement. So, we can rearrange the equation to solve for m3:
m3 = (m1v1 + m2v2)/v3
Substituting the values, we get:
m3 = (0.5 kg * 10 m/s + 0.3 kg * 20 m/s)/v3
m3 = (5 kg m/s + 6 kg m/s)/v3
m3 = 11 kg m/s/v3
Now, to find the velocity of the third piece, we can use the Pythagorean theorem to find the resultant velocity:
v3 = √(10^2 + 20^2)
v3 = √(100 + 400)
v3 = √500
v3 = 22.36 m/s
Finally, we can substitute this value back into our equation for m3 to get:
m3 = 11 kg m/s/22.36 m/s
m3 = 0.49 kg
Therefore, the mass of the third piece is 0.49 kg and its momentum is 3.3 kg m/s, which is the correct answer.
In conclusion, the key to solving this problem is to use the law of conservation of momentum and to consider the direction of each piece's momentum
FAQ: Provincial Exam: Simple momentum explosion question
1. What is a "simple momentum explosion" question on a provincial exam?
A simple momentum explosion question on a provincial exam is a physics problem that involves calculating the momentum of an object after it experiences an explosion. The question typically provides information about the mass and velocity of the object before and after the explosion, and asks the examinee to calculate the change in momentum.
2. How do I approach solving a simple momentum explosion question?
To solve a simple momentum explosion question, you should first identify the given information and the unknown variable. Then, use the formula for calculating momentum (p = mv) to find the initial and final momentums. Finally, subtract the initial momentum from the final momentum to calculate the change in momentum.
3. What are the key concepts to understand when solving a simple momentum explosion question?
The key concepts to understand when solving a simple momentum explosion question include the conservation of momentum, which states that the total momentum of a closed system remains constant, and the principle of action and reaction, which states that for every action, there is an equal and opposite reaction.
4. Are there any common mistakes to avoid when solving a simple momentum explosion question?
Yes, some common mistakes to avoid when solving a simple momentum explosion question include mixing up the initial and final velocities, forgetting to convert units (e.g. from km/h to m/s), and not considering the direction of the momentum vectors. It is important to carefully read and understand the question and to double check your calculations.
5. How can I prepare for a simple momentum explosion question on a provincial exam?
To prepare for a simple momentum explosion question on a provincial exam, you can review the key concepts and formulas related to momentum, as well as practice solving similar problems. You can also seek help from a teacher or tutor if you need further clarification or assistance. Additionally, familiarizing yourself with the format and types of questions on the exam can also be beneficial.
