Proving $a^b+b^a > 1$ for Positive Real $a,b$
  • MHB
  • Thread starter anemone
  • Tags
    Positive
In summary, we proved that for positive real numbers $a$ and $b$, the inequality $a^b + b^a > 1$ holds true. We first showed that $x^x > 1-\sqrt x$ for $0<x<1$ and then used this to prove the original inequality by considering the cases where $a$ and $b$ are less than $\frac12$. We also addressed a typo in the process.
anemone
MHB
POTW Director
3,883
115
If $a$ and $b$ are positive real numbers, show that $a^b+b^a>1$.
Mathematics news on Phys.org
$a^b>0,b^a>0 $ are the roots of the following equation :
$(x-a^b)(x-b^a)=0$
or $x^2-x(a^b+b^a)+a^bb^a=0$
let x=1, we have:
$1-(a^b+b^a)+a^bb^a=0$
$\therefore 1+a^bb^a=(a^b+b^a), \,\, and \,\, the\,\, proof \,\,is \,\, done$
I don't think that is a correct argument.
For example, $2$ and $3$ are roots of the equation $(x - 2)(x - 3) = x^2 - 5x + 6$ but if one sets $x = 1$ then $1 - 5 + 6 = 0$, a false equality.
note the values of :$a^b\, and \,\,\, b^a$ are variables ,not fixed
I though that didn't matter? Your equality was
$$a^b + b^a = 1 + a^b b^a$$
Which is clearly false if, say, $a = 3$ and $b = 4$.
in fact if a=0 or b=0 then :
$a^b+b^a= 1$
if we want to find $a^b+b^a>100$
a,b also can be found
now for all value of a>0 ,and b>0
we want to find the value of k with
$a^b+b^a>k$
if $a--->0^+ ,or\,\, b--->0^+$
we may cnclude:$a^b+b^a>1$
let $g(t)=t^2-(a^b+b^a)t+(a^bb^a)$
here $ a>0 ,\, b>0$
$g(1)=1-(a^b+b^a)+a^bb^a$
now let $g(1)=0$
we have:$1-(a^b+b^a)+a^bb^a=0---(*)$
this time we will find $a,\,and \,\,b$ satisfying (*)
this can be considered as
a linear equation :$1-y+x=0$
here $y=a^b+b^a ,\,\, x=a^bb^a$
so $y=1+x$
$\therefore y=a^b+b^a=1+a^bb^a>1$
and the proof is finished
here $ a>0 ,\, b>0$
now let $g(1)=0$
so $y=1+x$
not correct because g(1) = 0 is wrong pressumption
are you sure we can not find solutions
$(a^b,b^a)$ satisfying :
$1-(a^b+b^a)+a^bb^a=0\,\, ?$
[sp]First, I want to prove the inequality $x^x > 1-\sqrt x$, for $0<x<1.$ Taking logs, this is equivalent to $x\ln x > \ln(1-\sqrt x).$
Let $f(x) = x\ln x - \ln(1-\sqrt x).$ Then $f(x)\to0$ as $x\searrow0$. So to prove the inequality it will be enough to show that $f'(x)>0$ for $0<x<1.$ But $f'(x) = 1+\ln x + \dfrac1{2\sqrt x(1-\sqrt x)} > 1+\ln x + \dfrac1{2\sqrt x}$, because $\frac 1{1 - \sqrt x} > 1.$ So it will be enough to show that $g(x)>0$, where $g(x) = 1+\ln x + \dfrac1{2\sqrt x}$.
Differentiating again, \(\displaystyle g'(x) = \frac1x - \frac1{4x^{3/2}},\) which has a single zero when $x = \frac1{16}$. This turning point is a local minimum (as you can see by differentiating again), and $g\bigl(\frac1{16}\bigr) = 3-4\ln2 \approx 0.2274 > 0$. It follows that $g(x)>0$ throughout the interval $(0,1)$, as required. Working backwards, this means that the inequality $x^x > 1-\sqrt x\;\; (0<x<1)$ is proved.
Now we can look at the inequality $a^b + b^a > 1.$ It is obviously satisfied if either $a$ or $b$ is greater than $1$, so we may assume that they are both less than $1$. Next, notice that when $a,b \in (0,1)$, $a^b$ increases when $a$ increases, and it decreases when $b$ increases.
Suppose that $b < \frac12.$ Then $b^a > a^a > 1-a^{1/ 2}$ (by the above inequality). But $a^{1/ 2} < a^b$, and so $1-a^{1/ 2} > 1-a^b.$ Thus $b^a > 1-a^b$, so that the inequality $a^b+b^a >1$ is proved.
The same argument shows that the inequality holds when $a < \frac12.$ So we only have to look at the case when both $a$ and $b$ lie between $\frac12$ and $1$. But then $a^b+b^a > a+b >1.$ That completes the proof.[/sp]
if a or b are above 1 we are done,.so let us assume both < 1
by Bernoulli Inequality -- from Wolfram MathWorld we have$(1+x)^n \ge 1+nx$so $(1+\dfrac{a}{b})^{\dfrac{1}{a}} \ge 1+\dfrac{1}{b}$so $(1+\dfrac{a}{b})^{\dfrac{1}{a}} \gt \dfrac{1}{b}$or $1+\dfrac{a}{b} \gt (\dfrac{1}{b})^a$or $\dfrac{a+b}{b} \gt (\dfrac{1}{b})^a$or $\dfrac{b}{a+b} \lt b^a$similarly
$\dfrac{a}{a+b} \lt a^b$
Adding, we get $1 \lt a^b + b^a$
or $a^b+b^a \gt 1$
by Bernoulli Inequality -- from Wolfram MathWorld we have$(1+x)^n \ge 1+nx$so $(1+\dfrac{a}{b})^{\dfrac{1}{a}} \ge 1+\dfrac{1}{b}$so $(1+\dfrac{a}{b})^{\dfrac{1}{a}} \gt \dfrac{1}{b}$or $1+\dfrac{a}{b} \gt (\dfrac{1}{b})^a$or $\dfrac{a+b}{b} \gt (\dfrac{1}{b})^a$or $\dfrac{b}{a+b} \gt b^a$similarly
$\dfrac{a}{a+b} \gt a^b$
or $a^b+b^a \gt 1$
Nice proof!
How is that?
I like Serena said:
How is that?
Just a typo – a couple of the inequality signs are the wrong way round.
I like Serena said:
How is that?
I am sorry . There were typo Thanks for pointing. I have corrected the same.
Thanks for participating, Opalg! Thanks for giving us such a thorough proof and I appreciate that!:)
or $a^b+b^a \gt 1$
Hey kaliprasad,
This is one very elegant proof, well done and thanks for participating!
FAQ: Proving $a^b+b^a > 1$ for Positive Real $a,b$
What is the significance of proving $a^b+b^a > 1$ for positive real $a,b$?
The inequality $a^b+b^a > 1$ is an important result in mathematics and has implications in many fields such as number theory, geometry, and physics. It is also a fundamental concept in understanding the behavior of exponential and power functions.
How can you prove the inequality $a^b+b^a > 1$ for positive real $a,b$?
There are multiple approaches to proving this inequality. One way is to use the properties of logarithms and the AM-GM (arithmetic mean-geometric mean) inequality. Another approach is to use the concept of convexity and the Bernoulli's inequality. Both methods involve algebraic manipulations and the use of basic inequalities.
Can this inequality be extended to complex numbers?
No, this inequality only holds for positive real numbers $a,b$. For complex numbers, there is no clear definition of exponentiation and the concept of inequality is not well-defined.
Are there any special cases where $a^b+b^a$ equals 1?
Yes, when $a=b=1$, the inequality becomes $1+1=2 > 1$, which is true. However, for any other positive real numbers $a,b$, $a^b+b^a$ will always be greater than 1.
How is this inequality related to other mathematical concepts?
This inequality is closely related to the concept of convexity, the AM-GM inequality, and Bernoulli's inequality. It also has connections to the concept of growth rates and asymptotic behavior in calculus.
