Proving a function is well defined and continuous
In summary, we are trying to prove that the series f(x) = \sum^{\infty}_{n=1} f_{n}(x) is well defined and continuous on the interval [0,1]. We are working in a complete normed space (C[0,1], || . ||_{∞}). We have considered the real series \sum^{∞}_{n=1}||f_{n}||_{∞}=\sum^{∞}_{n=1} sup <f_{n}(x) : x\in[0,1]>, but we need to show that \sum^{∞}_{n=1}|f_{n}| converges. Some suggested methods include
mick25
Let [itex]f_{n}(x)=\frac{-x^2+2x-2x/n+n-1+2/n-1/n^2}{(n ln(n))^2}[/itex]
Prove [itex]f(x) = \sum^{\infty}_{n=1} f_{n}(x)[/itex] is well defined and continuous on the interval [0,1].
In a complete normed space, if [itex]\sum x_{k}[/itex]converges absolutely, then it converges.
Working in a complete normed space [itex](C[0,1], || . ||_{∞})[/itex],
consider the real series [itex]\sum^{∞}_{n=1}||f_{n}||_{∞}=\sum^{∞}_{n=1} sup <f_{n}(x) : x\in[0,1]> [/itex]
It just remains to show that [itex]\sum^{∞}_{n=1}|f_{n}|[/itex] converges, but I can't seem to figure out how. Could anyone help me out here?
some ideas i haven't tried them yet though... how about first separating n into some manageable pieces...
first evaluate the convergence of the terms only dependent on n, then consider the terms with an x and have a think about what x value will maximize that sum.
then if it's tough to pull it together you may want to consider some properties of the norm.
then I think you may need more for the continuous part and move to the epsilon deltas
Rather than dealing with all the terms separately, I've been trying to just apply a simple comparison test (followed by an integral test) to prove its convergence, but I could only come up with divergent cases.
I'm starting to think if there is an error with this question; does this series converge if it starts at n=1?
yeah as 1/ln(1)^2 is undefined
FAQ: Proving a function is well defined and continuous
What does it mean for a function to be well defined?
A function is well defined if each input has exactly one corresponding output. This means that for every possible input, the function produces a unique and unambiguous output.
How do you prove that a function is well defined?
To prove that a function is well defined, you must demonstrate that it produces a unique output for every possible input. This can be done by showing that the function follows a clear and consistent rule or formula, and that it does not produce any ambiguous or contradictory results.
What is the importance of proving that a function is well defined?
Proving that a function is well defined is important because it ensures that the function is reliable and consistent. It guarantees that for every input, the function will produce a unique and unambiguous output, which is essential for making accurate and meaningful calculations and predictions.
How is continuity related to the well-definedness of a function?
Continuity is closely related to the well-definedness of a function. A function can only be continuous if it is well defined, meaning that it produces a unique output for every input. If a function is not well defined, it cannot be continuous because it would have breaks or "jumps" in its graph.
What methods can be used to prove that a function is continuous?
There are several methods that can be used to prove that a function is continuous. These include the epsilon-delta definition, the intermediate value theorem, and the continuity of elementary functions. Additionally, a function can also be proven to be continuous if it is differentiable, as differentiability implies continuity.
