Proving a Matrix to be nonsingular
  • Thread starter B18
  • Tags
    Matrix
In summary: The chapter that this proof is from contains a small part on how the determinant cannot be 0 if the matrix has an inverse.What exactly does that part say? As you gave it here, it's of no use, since it starts with "if a matrix has an inverse" and you don't know that.It says "If the n x n matrix A is invertible, then it has n pivots. This means that the rank of A is n."In summary, given an n x n diagonal matrix A with nonzero diagonal elements, it is nonsingular and has an inverse matrix. This can be proven by showing that the determinant of A is not equal to 0, as stated in the theorem that
B18
118
Prove that if A is an n x n diagonal matrix with nonzero main diagonal elements; that is a(subscript)ii≠0 for all
1 ≤ i ≤ n, then A is nonsingular and find A(superscript)-1 (A inverse)
AB=BA=I(subscript)n
I first started out by stating that givens, such as A is an n x n diagonal matrix with nonzero diagonal elements. I then let B be an n x n matrix, and also stated that B is the inverse of A.
Am I on the right track here? Can I prove that AB=I(sub)n or BA=I(sub)n??
What allows us to know whether a matrix has an inverse i.e. is nonsingular?
Figuring out B should be easier than the proof itself.
When you multiply two diagonal matrices, in this case A and B, the product is a diagonal matrix where each entry is the product of the corresponding entries.
Use this and the fact that AB = I to determine B
The matrix must be square in order to have an inverse.
There must exist an n x n matrix B such that AB=BA=In.
You're on the right track. It has to be square and something else
For ex, a 2x2 square matrix of all zeros doesn't have a inverse. Why?
If the matrix A has an inverse that inverse is unique.
But how do we know it has an inverse in the first place? If I gave you a matrix
[2 3]
[1 4]
How do you get its inverse?
If that is A: AB=In.
[2 3][b11 b12] = [1 0]
[1 4][b21 b22] [0 1]
Then just multiply AB and set those equal to the identity matrix.
B18, you're not using a very important piece of the given information -- your matrix A is diagonal.
You can't assume that B is the inverse of A; i.e., that B = A-1. You have to first show that A has an inverse; that is, is nonsingular. There is an important tool that can be used on square matrices to determine whether they are singular or nonsingular.
As Mark said, you cannot assume that A has an inverse matrix and then set out on finding it. You need a way to see if it has an inverse before you can attempt to use your method to solve that example problem I gave you.
For a square matrix to be nonsingular the determinant cannot equal 0.
Bingo!
And calculating the determinant of a diagonal matrix is very easy. For your matrix, aii ≠ 0, for i = 1, ..., n, so what is |A|?
On the other hand, if you have some given matrix A and I hand you a matrix B and ask you if B is the inverse of A, you don't need to know if A has an inverse; you just need to check if AB = I. That could be the situation if I started blindly using a matrix-inversion algorithm on your A and it went all the way to the end without encountering any problems.
Well A should be: a11a22 if it were a 2x2 matrix.
Do you mean |A| -- the determinant of A? In any case, the given matrix is n x n.
Yes the determinant of A would be that. So in my proof I need to state that the determinant of A is not zero because it has nonzero diagonal values. Correct?
Instead of just stating that |A| ≠ 0, your proof would be more convincing if you showed that it was not zero. In your class have you spent any time on determinant properties and theorems?
Mark- We have not covered the determinant properties or theorems yet. They are in the next chapter. The chapter that this proof is from contains a small part on how the determinant cannot be 0 if the matrix has an inverse.
Am I going to need to write out the A and B matrices in order to prove this? All the proofs in this section thus far have been denoted by A,B, and C. I haven't yet done a proof where i needed to write out the matrix and fill in the entries.
There is no matrix B given in this problem. All you have to go on is an n X n diagonal matrix A.
If A is a 2 x 2 matrix given by
A=[a b]
...[c d]
then A is invertible if and only if ad-bc ≠ 0. Moreover, if ad-bc≠0, then the
inverse is given by
1/(ad-bc) * [a b]
... [d c]
A=[a b]
...[c d]
inverse is given by
1/(ad-bc) * [a b]
... [d c]
None of this is relevant. The matrix in your problem is n x n and diagonal.
You said there was a short section on determinants in your book. What exactly does it say?
Mark it is a small comment the book makes about the determinant of A being ad-bc, and how this topic will be covered later in the text.
However I found this- adjoining the matrix A with the identity matrix I: [ A I ] then use elementary row options to get the form to [ I A-1 ]
"The process shown in Example 3 applies to any n x n matrix A and will find the inverse of A, if it exists." - From the book in regards to the method above.
This is called "finding the inverse of a matrix by Guass-Jordan Elimination". I believe this is the way I need to prove this. All other theorems in my textbook involve bringing in a second matrix B (which is assumed to be the inverse of A).
What does your book say about diagonal matrices?
I looked in the index of the book and it only gave two pages for diagonal matrices. One was a homework problem with a diagonal matrix. The other page was in the determinants chapter explaining the determinant of a diagonal matrix is a11a22a33...ann
I guess this is the way you need to go...
Im going to go with that method. Thank you very much for your help Mark, and everyone else. Greatly appreciated.
Related to Proving a Matrix to be nonsingular
What does it mean for a matrix to be nonsingular?
A matrix is considered nonsingular if it has an inverse, meaning it can be multiplied by another matrix to produce the identity matrix. This means that the matrix has a unique solution for every set of linear equations that it represents.
Why is proving a matrix to be nonsingular important?
Proving a matrix to be nonsingular is important because it guarantees that the matrix has a unique solution for every set of linear equations it represents. This is crucial in solving systems of equations in various fields, such as engineering, physics, and economics.
How can you prove a matrix to be nonsingular?
One way to prove a matrix to be nonsingular is by determining its determinant. If the determinant is non-zero, then the matrix is nonsingular. Another method is by using row operations to reduce the matrix to its row echelon form. If the resulting matrix has a row of zeroes, then the original matrix is singular.
What are the consequences of a singular matrix?
A singular matrix has no inverse, meaning it cannot be used to solve a system of equations. This can lead to inconsistent or infinite solutions, which can have significant consequences in real-world applications. It can also make computing the solution to a system of equations more difficult and time-consuming.
Can a matrix be nonsingular and singular at the same time?
No, a matrix cannot be both nonsingular and singular at the same time. If a matrix is nonsingular, it means it has an inverse and is therefore not singular. If a matrix is singular, it has no inverse and is therefore not nonsingular.
  • Linear and Abstract Algebra
