Proving a number is irrational.
  • Thread starter cragar
  • Tags
    Irrational
In summary, the conversation discussed how to prove that log_2(3) is irrational. The attempt at a solution involved using the definition of logs and a proof by contradiction. It was shown that assuming x is rational leads to a contradiction, therefore x must be irrational.
cragar
2,552
Prove that [itex] log_2(3) [/itex] is irrational.
This is also equivalent to [itex] 2^x=3 [/itex] from the definition of logs.
Proof: For the sake of contradiction let's assume that x is rational and that their exists integers P and Q such that x=P/Q .
so now we have [itex] 2^{\frac{P}{Q}}=3 [/itex]
now I will take both sides to the Q power .
so now we have [itex] 2^P=3^Q [/itex]
since P and Q are integers, there is no possible way to have 2 raised to an integer to equal 3 raised to an integer, because 2^P will always be even and 3^Q will always be odd. so this is a contradiction and therefore x is irrational.
Looks good :)
sweet ok , I'm new to writing proofs so just want some confirmation.
I can't imagine that you would lose points for this, but for the sake of pedantry you might want to point out that P and Q would have to both be positive integers. Just because 2^0=3^0 and 2^P, 3^Q aren't even and odd respectively when P and Q are negative.
FAQ: Proving a number is irrational.
What is an irrational number?
An irrational number is a number that cannot be expressed as a fraction of two integers. These numbers have an infinite number of decimal places that do not repeat in a pattern.
How do you prove a number is irrational?
To prove a number is irrational, you must show that it cannot be expressed as a fraction. This can be done through various methods such as proof by contradiction, proof by induction, or proof by construction.
Can a number be both rational and irrational?
No, a number cannot be both rational and irrational. A number is either one or the other, but not both. For example, pi (π) is irrational while the number 1 is rational.
What are some examples of irrational numbers?
Some examples of irrational numbers include pi (π), the square root of 2 (√2), and the golden ratio (φ). These numbers cannot be expressed as a fraction and have an infinite number of non-repeating decimal places.
Why is proving a number is irrational important in mathematics?
Proving a number is irrational is important because it helps us understand the nature of numbers and their relationships. It also allows us to solve certain problems and make accurate calculations in fields such as geometry, physics, and engineering.
