Proving a result about invertibility without determinants
  • I
  • Thread starter Mr Davis 97
  • Tags
    Determinants
In summary, when considering nxn matrices over an arbitrary field such that AB = -BA, it can be proven that if n is odd, then either A or B is not invertible. This can be shown using determinants, but it is also possible to prove it without using determinants by using the concept of normal forms and the characteristic matrix. However, it is important to note that the field used must have the condition that 1 is not equal to -1.
Mr Davis 97
1,462
44
Let A and B be nxn matrices over an arbitary field such that AB = -BA. Prove that if n is odd then A or B is not invertible.
This is rather easy when we use determinants. However, I am curious, how hard would it be to prove this without the use of determinants? What would be involved in such a proof, and how much more work would it be when compared to just using determinants?
I have no idea except to describe the determinant by geometric means which wouldn't really be another approach. However, "arbitrary field" is wrong. One has to require a certain condition on the field.
assume A invertible and prove B is not.
i think it implies they (B and -B) are similar, hence have the same jordan form, and that blocks with diagonal constant c are balanced by equal size diagonal blocks with constant -c. Hence odd size suggests some c = -c = 0. (Pass to algebraic closure to use jordan form.) Of course as fresh 42 warned, it is prudent to require 1 ≠ -1 in the field used.
so this is using ideas actually more powerful than determinants but also more conceptual.
normal forms may be obtained by diagonalizing the characteristic matrix with no specific mention of determinants, but they are there as the constant term of the characteristic polynomial (defined as the product of the diagonal entries of the diagonalized characteristic matrix.)
Related to Proving a result about invertibility without determinants
1. Can a result about invertibility be proven without using determinants?
Yes, there are several alternative methods for proving invertibility without using determinants, such as using matrix properties or linear transformations.
2. What are some advantages of proving invertibility without using determinants?
One advantage is that it allows for a deeper understanding of the underlying concepts and properties of matrices. It also provides alternative approaches for solving problems and can be useful in situations where determinants are not defined or difficult to compute.
3. Are there any limitations to proving invertibility without using determinants?
Yes, there are certain cases where using determinants may be more efficient or necessary for proving invertibility. Additionally, some proofs may require a combination of methods, including determinants.
4. How does proving invertibility without using determinants relate to real-world applications?
Invertibility is a fundamental concept in linear algebra and is applicable in many real-world scenarios, such as in engineering, economics, and physics. By understanding alternative methods for proving invertibility, scientists can apply these concepts to a wider range of problems and situations.
5. Can the same result about invertibility be proven using both determinants and alternative methods?
Yes, in most cases, the same result can be proven using both determinants and alternative methods. However, there may be instances where one method may be more efficient or appropriate compared to the other.
  • Linear and Abstract Algebra
50K
