Proving a statement about the rank of transformations
In summary, the conversation discusses how to prove the inequality ##max\{0, \rho(\sigma)+\rho(\tau)-m\}\leq \rho(\tau\sigma)\leq min\{\rho(\tau), \rho(\sigma)\}##, where ##\rho## represents the rank of a linear transformation. The first attempt at a solution involves using Corollary 1.11 and the general formulas for rank and nullity. The second attempt involves using Theorem 1.4 and the general formulas. There is also a discussion about the relationship between kernels and images, and how to use them to prove the desired inequality.
Terrell
317
How to prove ##max\{0, \rho(\sigma)+\rho(\tau)-m\}\leq \rho(\tau\sigma)\leq min\{\rho(\tau), \rho(\sigma)\}##?
Let ##\sigma:U\rightarrow V## and ##\tau:V\rightarrow W## such that ##dimU=n##, ##dimV=m##. Define ##v(\tau)## to be the nullity of ##\tau##, ##\sigma## and ##\tau## are linear transformations, and ##\rho## means rank of the linear transformation
proof (attempt 1):
By Corollary 1.11, ##\rho(\sigma)=\rho(\tau\sigma)+v(\tau)$ $\Leftrightarrow## ##\rho(\sigma)-v(\tau)=\rho(\tau\sigma)##. Note that ##v(\tau)\leq m## \begin{align}\Rightarrow \rho(\sigma)-m &\leq \rho(\tau\sigma)\\ \Rightarrow \rho(\sigma)-(\rho(\tau)+v(\tau)) &\leq \rho(\tau\sigma)\\ \Rightarrow \rho(\sigma)-\rho(\tau)-m &\leq \rho(\tau\sigma)\end{align}
proof (attempt 2):
By Corollary 1.11, ##\rho(\sigma)-m\leq \rho(\tau\sigma)##. This implies ##\rho(\sigma)-m+\rho(\tau)\leq\rho(\tau\sigma)+\rho(\tau)\Rightarrow \rho(\sigma)+\rho(\tau)-m\leq\rho(\tau\sigma)+\rho(\tau)##.
I am stuck. Is it possible to this relationship intuitively?
Say we have ##U_n \stackrel{\sigma}{\longrightarrow} V_m \stackrel{\tau}{\longrightarrow} W_k##.
Then - I think - we already have the general formulas ##n=\rho(\sigma) + \nu(\sigma)\, , \,n=\rho(\tau \sigma) + \nu(\tau \sigma)## and ##m=\rho(\tau) + \nu(\tau)##. Now all you need is some substitution and ##\nu(\tau \sigma) \leq \nu(\sigma)+\nu(\tau)##. The second inequality is more or less obvious as you cannot gain linear independent vectors by a transformation. The images can only shrink.
Likes Terrell
Using the general formulas... please check the proof that follows:
Note that ##\rho(\sigma)+\rho(\tau)-m=\rho(\sigma)-(m-\rho(\tau))=\rho(\sigma)-v(\tau)## and ##\rho(\tau\sigma)+v(\tau\sigma)=n\Rightarrow \rho(\tau\sigma)=n=v(\tau\sigma)##. By Theorem 1.4., ##\rho(\sigma)\leq min\{m,n\}\Rightarrow \rho(\sigma)\leq n\Rightarrow \rho(\sigma)-v(\tau)\leq n-v(\tau)##. Since ##K(\tau\sigma)\subset K(\tau)\Rightarrow v(\tau\sigma)\leq v(\tau)\Rightarrow -v(\tau\sigma)\geq -v(\tau)##. Then \begin{align}n-v(\tau)\leq n-v(\tau\sigma)&\Rightarrow \rho(\sigma)-v(\tau)\leq n-v(\tau\sigma)\\&\Rightarrow \rho(\sigma)-(m-\rho(\tau))\leq \rho(\tau\sigma)\\&\Rightarrow \rho(\sigma)+\rho(\tau)-m\leq \rho(\tau\sigma)\end{align}
and ##\rho(\tau\sigma)\leq min\{\rho(\sigma),\rho(\tau)\}## directly follows from Theorem 1.4.
##\Bbb{Q.E.D.}##
fresh_42 said:
Now all you need is some substitution and ν(τσ)≤ν(σ)+ν(τ)
I don't know how this inequality gets into the picture, but it's part of the next proof i want to write so.. proving the inequality i have:
##K(\tau\sigma)=K(\tau\vert_{\sigma(U_{n})})\Rightarrow K(\tau\sigma)\subset K(\tau)\Rightarrow v(\tau\sigma)\leq v(\tau)\Rightarrow v(\tau\sigma)\leq v(\tau)+v(\sigma)##
Typo.
Assuming ##K## shall denote the kernel, we have ##K(\tau \sigma) \subseteq U_n## and ##K(\tau) \subseteq V_m\,,## so how can ##K(\tau\sigma)\subset K(\tau)## be?
Furthermore, let's assume ##n>m>0\, , \,V_m=W_k\, , \,\tau = \operatorname{id}|_{V_m}## and ##\sigma = 0##. Then ##\nu(\tau \sigma) = n > m > 0 = \nu(\tau)##.
Likes Terrell
See my previous correction.
fresh_42 said:
how can K(τσ)⊂K(τ)K(τσ)⊂K(τ)K(\tau\sigma)\subset K(\tau) be?
I think I ran into trouble here by assuming that ##K(\tau\sigma)=K(\tau\vert_{\sigma(U_n)})##, where ##K(\tau\vert_{\sigma(U_n)})## means Kernel of ##\tau## strictly on ##\sigma(U_n)##. It's an incorrect assumption? Because certainly, ##K(\tau\vert_{\sigma(U_n)})\subset K(\tau)##.
fresh_42 said:
Then - I think - we already have the general formulas n=ρ(σ)+ν(σ),n=ρ(τσ)+ν(τσ)n=ρ(σ)+ν(σ),n=ρ(τσ)+ν(τσ)n=\rho(\sigma) + \nu(\sigma)\, , \,n=\rho(\tau \sigma) + \nu(\tau \sigma) and m=ρ(τ)+ν(τ)m=ρ(τ)+ν(τ)m=\rho(\tau) + \nu(\tau). Now all you need is some substitution and ν(τσ)≤ν(σ)+ν(τ)ν(τσ)≤ν(σ)+ν(τ)\nu(\tau \sigma) \leq \nu(\sigma)+\nu(\tau).
I think this is the way to go. Now to show ##v(\tau\sigma)\leq v(\tau)+v(\sigma)##, I started by defining ##K(\tau\sigma)=\{\zeta\in U_n\mid \sigma(\zeta)\in K(\tau)\lor \sigma(\zeta)=0_V\}##.
Likes fresh_42
Yes, but not the first assumption on ##K(\tau \sigma)##. That's why I wrote ##\nu(\tau \sigma) \leq \nu(\tau) + \nu(\sigma)##, if a vector is sent to zero by a composite function, then either by the first or by the second, so the sum is the secure side. But your argumentation is fine for the second inequality in your initial post, and with images instead of kernels. ##\operatorname{im}(\tau \sigma) \subseteq \operatorname{im}(\tau)## gives one inequality, and that the ##\tau## cannot increase the rank of ##\sigma## gives the other inequality which is needed for the minimum.
Terrell said:
Do you think my current approach is futile?
No, just a bit more cautious. I think you've been on the right track. Just substitute all three ranks by the formula ##\rho(\alpha)+\nu(\alpha)=\dim X## for a ##\alpha:X \rightarrow \,\ldots## and then use what I said above and in post #2: ##\nu(\tau \sigma)\leq \nu(\tau) + \nu(\sigma)##.
fresh_42 said:
Yes, but not the first assumption on K(τσ)K(τσ)K(\tau \sigma). That's why I wrote ν(τσ)≤ν(τ)+ν(σ)
So ##K(\tau\vert_{\sigma(U_n)})=K(\tau\sigma)##?
Is this correct with ##\sigma =0## and ##\tau = \operatorname{id}\,##?
Likes Terrell
I found the perfect theorem from the book I'm working on that fits the proof, perfectly!
By that theorem, ##\rho(\sigma)=\rho(\tau\sigma)+dim[\sigma(U)\cap K(\tau)]## \begin{align}\Rightarrow dim[\sigma(U)\cap K(\tau)]&=\rho(\sigma)-\rho(\tau\sigma)\\&=(n-v(\sigma))-(n-v(\sigma))\\&=v(\tau\sigma)-v(\sigma)\\&=dim[K(\tau\vert_{\sigma(U_n)})]\\&=v(\tau\vert_{\sigma(U_n)})\\ \Rightarrow v(\tau\sigma)=v(\tau\vert_{\sigma(U_n)}+v(\sigma)\leq v(\tau)+v(\sigma).\end{align} ##\Bbb{Q.E.D.}##
Related to Proving a statement about the rank of transformations
1. What is the definition of "rank" in transformations?
The rank of a transformation is the number of linearly independent columns or rows in the transformation matrix. It represents the number of dimensions in the output space that are affected by the transformation.
2. How is the rank of a transformation calculated?
The rank of a transformation can be calculated by finding the number of pivot positions in the reduced row-echelon form of the transformation matrix. Alternatively, it can also be found by counting the number of non-zero singular values in the singular value decomposition of the matrix.
3. What does it mean if the rank of a transformation is less than the number of input variables?
If the rank of a transformation is less than the number of input variables, it means that the transformation is not invertible and some information is lost in the transformation. This can happen if there are redundant or linearly dependent input variables.
4. How do you prove a statement about the rank of transformations?
To prove a statement about the rank of transformations, you can use mathematical techniques such as Gaussian elimination, row-reduction, or the singular value decomposition. These methods can be used to manipulate the transformation matrix and show that the rank remains the same before and after the transformation.
5. Why is the rank of transformations important?
The rank of transformations is important in many areas of mathematics and science, including linear algebra, differential equations, and data analysis. It helps us understand the properties of a transformation and its effect on the input and output variables. It also allows us to determine if a transformation is invertible and to solve systems of equations.
  • Linear and Abstract Algebra
