Proving a theorem in line integrals
In summary, the conversation discusses the concept of path independence in calculus and how it relates to differentiating a function with respect to x. The conclusion is that choosing specific paths is necessary to ensure the validity of the calculation.
anhtu2907
At the bottom of the picture, I couldn't understand why differentiating with respect to x gives the first integral at the right-hand side 0. Thanks for reading.
In my opinion, that is simply wrong. Rather than taking [itex]C_1[/itex] to be "any path from (a, b) to [itex](x_1, y)[/itex]" we must choose [itex]C_1[/itex] to be the vertical line from (a, b) to [itex](a, y)[/itex] then take [itex]C_2[/itex] to be the horizontal line from [itex](a, y)[/itex] to [itex](x, y)[/itex].
I'm no math pro, but my guess would be that since you have the hypothesis that your integral is path independent, then
[tex]
\int_{C_1} F\cdot dr = \int^{(x1,y)}_{(a,b)} F\cdot dr = f(x1,y) - f(a,b)
[/tex]
which differentiated w.r.t. x gives 0 and w.r.t. y does not (since the point (x,y) is arbitrary, y is arbitrary but x1,a,b are fixed)
Related to Proving a theorem in line integrals
1. What is a line integral?
A line integral is a mathematical concept used to calculate the total value of a function along a given curve in a two or three-dimensional space. It is represented by the symbol ∫, and is often used in physics and engineering to calculate work, force, and other physical quantities.
2. How do you prove a theorem in line integrals?
To prove a theorem in line integrals, you must first clearly state the theorem and its assumptions. Then, you must use mathematical techniques such as substitution, integration by parts, or change of variables to manipulate the integral and show that it is equal to the desired result. It is also important to provide a logical and step-by-step explanation of your reasoning.
3. What is the significance of proving a theorem in line integrals?
Proving a theorem in line integrals allows us to understand and validate the mathematical concepts and principles behind the calculations we use in physics and engineering. It also helps us to develop a deeper understanding of the relationships between different quantities and how they interact with each other.
4. What are some common techniques used in proving theorems in line integrals?
Some common techniques used in proving theorems in line integrals include substitution, integration by parts, and change of variables. These techniques allow us to manipulate the integrals and simplify them to a point where the desired result can be easily obtained.
5. Are there any real-world applications of line integrals?
Yes, line integrals have many real-world applications in physics and engineering. For example, they are used to calculate work done by a force on an object, electric potential in a circuit, and fluid flow in a pipe. They are also used in vector calculus to solve problems related to fields such as electric, magnetic, and gravitational fields.
